Question about Belkin F5D7234-4 Router
Have a desktop with cable internet - installed router and added my laptop to wireless - it picked up the signal and connected and put in password no problem. Tried to do same with my cousins laptop from Canada (Dell Laptop) wireless signal there but won't let me connect to internet with password. tried installing the CD and keeps saying not connected to the Internet. How can I connect another laptop wirelessly through my router?
    Problem Solver:
  • 9 Answers
You would connect a laptop from Canada the same way as one from the US. You want to make sure the wireless card is turned on and check for wireless networks. Once you have found your network select it make sure you type the password correctly.
Posted on Dec 30, 2010
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
When i hook it up i get the laptop to pick up the signal but the desktop will not go online
on the hind side of the modem how many ports do you see
my guess one port slightly seperated and named INTERNET or WAN and four more ports numbered 1,2,3,4
now connect the network cable from the modem to the WAN / INTERNET port and connect the laptopand PC to the ports1,2
now check to see if there is connection to only on Laptop or both
but if you have conection to only the laptop/PC connected to port1 then try this small trick
move the laptop to port 3 and in port 1 connect the cable from the modem which was connected to the WAN / INTERNET port
and u r set to go
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link DI-524 works with desktop, but laptop can't get signal
Try opening internet explorer and typing in http://192.168.0.1 in the address box
If this doesn't work try http://192.168.1.1
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
My desktop uses a DSL internet connection but my lap top will not pick up the signal from it to connect even when I have it sitting right next to my desktop. If I actually unplug yellow connection cord...
Having your laptop sitting next to your desktop will not let your laptop connect to the DSL link.
You need what's called a Wireless Router. (assuming your laptop has a wireless adapter, if not you'll need a network cable for that.
1. Go to the store, buy a wireless router
2. install router in between your DSL modem and the computer.
3. Plug the WAN port into the DSL modem (cable is usually included with the router)
4. Plug the desktop into the back of one of the ports of the wireless router
5. Run the setup disk
6. For manual configuration of the router you can usually go to: 192.168.0.1 or 192.168.1.1 or 192.168.2.1 depending on the brand)
7. If you don't know anything about networking, let the install disk do all the work.
8. Follow the instructions on what it tells you your configuration is for your wireless network.
9. Go to your laptop, apply said instructions.
10. ???
11. Profit.
Dec 02, 2008 | Acer Aspire 5050-3242 Notebook
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Router won't log into it's IP address online
Is your desktop getting an ip address from the router?
You said that you reset the router, do you mean turning it on and off or pressing the reset button?
Aug 03, 2008 | NetGear WGT624 Wireless Router
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
WRT54GX2 Wireless-G disrupts both laptop and desktop internet connections
it might be because of interference...no issues dont worry about that...
JUst follow these steps and the issue will be resolved....
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
STEPS FOR WIRELESS CONFIGURATION
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
user name and password..leave the user name blank and the password will be admin.
7,
U can see the option WIRELESS in the black bar..click on wireless..
Wireless network mode should be "Mixed".wireless network name can be ur first name or
anyother name.select the channel as 11 and the SSid broad cast should be Enabled.click on
save settings.it will say like "Settings are successful"click continue.
8,to set the password for ur wireless network...below wireless tab in the black bar..u will
find a blue bar which says "wireless security".click on "wireless security". Security mode
should be "WEP"..Default transmit key should be 1.wep encryption should be 64
bits..passphrase should be empty..in the key 1 box enter ur 10 digit telephone number(ur
telephone number will be ur password for the wireless connection)click save settings and
continue..
9,
now in the laptop check whether the wireless switch is turned on...u can find ur wireless
signal..while connecting it will prompt for a password.enter ur telephone number there..
u will be connected to the internet..
Jun 01, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
ADDING A LAPTOP
Does your wireless router supply DNS addresses via DHCP or are they configured into the wireless adapter on the other computer? If the DNS addresses are configured into the working laptop's wireless adapter and not the router -- they may need to be configured into the wireless adapter of the new laptop. Is there a proxy server configured into the browser of the new machine that should not be there or does not match the working machine? Is the new laptop statically configured to an inappropriate IP address or gateway or DNS servers for the network you are attempting to use it on.
Dec 13, 2007 | Linksys Wireless-G WRT54G Router...
Belkin F5D7234-4 Router Logo
52 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
