Question about HP Office Equipment & Supplies
I have a HP laserjet cm1312nfi when i turn on the power it seems to be booting. The lcd shows the hp logo with a bar going across. After loading for a few seconds the memory reader light begins to flash. The screen will then turn purple and the exclamation mark and the ready light begin to flash. I have checked for jams,removed the paper tray even replaced the toner still no luck. I reset the logic card still no help. Can somebody give me anything I can try? Thank You
  • 8 Answers
Have you check garbage drum status
Posted on Mar 09, 2015
Printerguru
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
SOURCE: Red "Paper" light blinking Brother HL-2040
THANKS MY PROBLEM IS SOLVED THERE WAS A PAPER JAME WITHIN THE DRUM AREA OPEN UP THE DRUM AREA BY REMOVING THE TONER CARTRIDGE AND IT SHOULD WORK
Posted on Jul 15, 2008
  • 138 Answers
SOURCE: hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
Posted on Aug 03, 2008
  • 461 Answers
SOURCE: Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Posted on Jan 22, 2009
FixinFax
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
WIl not print correctly
If it is faded, it could be the transfer roller. I've had great success with simply periodically cleaning it, then getting a good printout. See my solution for this already posted: Check out this solution to the HP Color LaserJet CM1312nfi Laser Color...
Otherwise, the other issue I had late last year was that it needed a new intermediate transfer belt (part #RM1-4436-000CN). You can find a good deal on one, and the instructions for replacement are on page 156 in the service manual: http://www.feedroller.com/Store/Service%20Manual/HP-CLJ-CM1312-MFP-Manual.pdf
It's not the hardest replacement ever, but needs 2-3 hours depending on skill, and a little patience.
Mar 28, 2014 | HP Color LaserJet CM1312nfi Laser Color...
How to scan to PDF
This question was answered in HP communities, pleas look at the screenshot attached on this page: http://h30499.www3.hp.com/t5/Multifunction-and-All-in-One/Scanning-to-PDF-with-Hp-color-laserjet-cm1312nfi-Mfp/td-p/1110889
Feb 26, 2013 | HP LaserJet CM1312 All-In-One Printer
Hp laserjet 4250 error 58.20
1 Turn the printer off and then on.
2 Reconnect the connector between the air-temperature sensor (the bar mounted across the main cooling fan
on the left side of the printer) and the power supply.
3 Replace the air-temperature sensor.
4 Replace the power-supply assembly.
Oct 16, 2012 | HP LaserJet 4250dtn Printer
Hp cm1312nfi printer problem error ready to download
The error is due to corrupt firmware and you need to reinstall it.
HP CM1312NFI Firmware Download & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the pc during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP LaserJet CM1312 All-In-One Printer
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
I have an HP CM1312Nfi that when I power it on it will display the progress bar and will have the warning light flashing. The progress bar will almost finish and it reboot and restart the progress bar. No...
Hello Luis !
This problem is isually related to a hardware failure, commonly on the formatter (MainBoard), but there are a few steps you can do to recover it:
1) Make sure the printer is connected straight to the wall
2) Try doing an NvRam or Hardreset on the printer, for the 1312nfi just follow this steps:
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
3) If the printer goes back to ready, i would recommend you to download the latest Firware Update for the 1312nfi, you can download it from this link, just select you operation system from the list:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3562006&taskId=135&prodTypeId=18972&prodSeriesId=3558902&lang=en&cc=us
Now, if the printer is not comming back to ready just turn the printer off, and with the printer off run this firmware update on your computer and finally turn the printer back on.
If after all of this you cannot get the printer to work, that means the formatter board is defective and need to be replaced
Since this is a new hp model it may be still under warranty so you call HP Tech support 1 800 334 51 44 (US)
or take the printer to an HP Authorized repair center, heres a link to find one near to your location:
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Hope this can help you!
Bryan
eliteprintersolutions@gmail.com
Jul 16, 2010 | HP LaserJet CM1312 All-In-One Printer
HP cm1312nfi control-panel display WHITE, it still...
Try doing a hard or reset or nvram:
1. Turn the printer off, disconnect the phone line
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If the lcd does not display anything contact hp or a local service provider as there is a definite power failure.
Al
Eliteprintersolutions@gmail.com
May 20, 2010 | HP LaserJet CM1312 All-In-One Printer
HP LaserJet 2420dn display is blank when powering on.
I had the same problem here. Removed memory and put it in the other slot and problem solved!
Feb 22, 2010 | HP LaserJet 2420dn Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
213 people viewed this question
Seeker5211
Seeker5211
