Question about Hoover HDC7FM Dryer
I have a Hoover HDC7FM. The 'Filter Light' is staying on even when the filter has just been cleaned. The Tumble Dryer turns on, but does not heat or dry the clothes.
SOURCE: I have a hoover Nextra
My nextra has just started to do same thing, does anyone know what is wrong
Posted on Jun 11, 2008
  • 21 Answers
SOURCE: hoover dryer tce660 filter light
Check vent pipe for lint or out side flap stuck shut
Posted on Jun 24, 2008
  • 66 Answers
SOURCE: Dryer not heating Enough
Ceck the vent hose and vent. Make sure these are clear of obstruction. This is tipical of poor venting. The dryer can`t remove the moist air to dry the clothes properly.
Posted on Nov 14, 2008
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My hoover condenser dryer model
Hi Alan....
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
Hoover tumble dryer vhv 380 filter care light constantly on even thou there all spotless .....please help
Please vacuum the lint filter housing and check the outside vent on your house for any lint build-up.
Oct 16, 2015 | Hoover Dryers
Filter light comes on after cleaning nothing happens and no heat
clean the sensor beneath the lint trap, be careful as not to damage it
Mar 13, 2011 | Hoover HDC7FM Dryer
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
Hoover tumble dryer filter light staying on and blowing cold air
if you have cleaned your filter at the door and checked the outlet is not blocked either then it will most likely be the heater element on the back of the machine, it has three parts to it, 1 thermal switch,2 is some sort of magnetic type switch and 3rd is the element its self,
problem is its only sold as one unit, but very easy to replace.
Jun 05, 2009 | Zanussi TC7102W Electric Dryer
Dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
Feb 19, 2009 | Hoover HDC7FM Dryer
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Tumble Dryer not getting hot
its your thermostat mate they cost 30quid simle to fit
Jul 06, 2008 | Dryers
Hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Feb 26, 2008 | Dryers
Hoover HDC7FM Dryer Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
