Using my logik shredder the machine stopped due to blockage which i have noe removed but it wont start again only a high pitched whine in both forwards and backwards mode
IrishDruid
  • 2712 Answers
SOURCE: Rexel 3250 S3 wont stay in continuous mode
Try a hard reset first..Unplug the machine from power source, wait about 10 minutes, and try again..
Posted on Jun 07, 2008
leroyal
  • 2120 Answers
SOURCE: Fellowes DM8C shredder will run
It sounds like a bad switch assembly. I don't think spare parts are available.
Try blowing out the switches with canned air.
Posted on Nov 16, 2008
  • 39 Answers
SOURCE: High Pitch whine during acceleration
Hi Pullerwife,
I have a few suggestions for you,
First of all, check your air filter, make sure its clean, not clogged, and doesn't need to be changed.
I don't know how handy you are, but if you are fairly handy, check the idler pulley bearings, if your not, have a shop check it out, as a last resort.
Power steering pump/fluid being low is also a possibility, but thats usually more of a lower pitched whine then what you describe.
You say once the vehicle is warmed up, the whining stops. Does Weather seem to be a factor as well?
Hope I've helped, and don't forget to rate.
Lazaruselite
Posted on Feb 25, 2009
advacak
  • 125 Answers
SOURCE: motor sounds loud and high pitched
most likely your bearings are shot. it will need a new motor
Posted on Mar 09, 2009
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
Need help finding & solving high pitch whine at mid to high speeds
It sounds like a Bearing is worn in one of the wheels or in the Drive-shaft. Get a mechanic to check it out
Jan 15, 2014 | 1994 Ford Crown Victoria
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
When I turn on the key, all I get is a high pitch whine. The engine does not sound like it is rolling over.
Starter not engaging flywheel, timing out on motor can cause this due to noe load.
Jan 30, 2010 | 2004 Mazda RX-8
Staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Jun 16, 2009 | Office Equipment & Supplies
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
It's screaming at me ~ squealling loudly.
the cutter wheels in side the machine needs to be lubricated. use a silicone lube. like tri-flo. Spray the lube where you put the paper
Jan 23, 2009 | Achiever SCS-6 Strip-Cut Shredder
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Open Questions:
k24674
