Apple MacBook Mac Notebook Logo
Posted on Dec 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop has suddenly frozen, i turned it off by the power button and whenever i try to turn it on it turns white screen, then shutsoff after 3-5minutes.
seabreezecat
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 23, 2015
 seabreezecat
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
2054
Points
14
If the above doesn't help, you need to have the logic board replaced by Apple. Been there, done that, and it's not too expensive.
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Apple Master 7,733 Answers
  • Posted on Dec 30, 2010
Apple Master
Level 3:
Answers
7733
Questions
0
Helped
1864912
Points
21487
Resolution
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter, learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
Also:
The MacBook SMC Firmware Update v1.1 improves the MacBook's internal monitoring system and addresses issues with unexpected shutdowns. This update is recommended for all MacBook systems, including those that received warranty repair.
You can use the Software Update feature of System Preferences, or download the MacBook SMC Firmware Update v1.1 from Apple Software Downloads.
Note: If your MacBook is running Mac OS X 10.4.6, you won't be able to see the SMC Update until you update to Mac OS X 10.4.8. Once you have updated your system software, the SMC Update will appear as an option in Software Updates.
MacBooks running Mac OS X 10.4.7 will be able to download and install the SMC Update, so it is not essential that you update your system software, although Apple always recommends updating to the latest version of the system software.
If your MacBook is in a state where it will not remain on long enough to install the update, wait for the issue to reproduce itself. Once the MacBook has turned itself off, turn the computer on by holding the power button down. Keep the button down until you hear a single long tone. Once you hear the tone you can release the button, install the recommended updates, and restart normally.
Frozen screen on Dell Inspiron, can not reboot
if you hold the power button for 30 seconds to 1 minute, it will eventually turn off. Another thing you can try it removing the battery (If there is one) as well as unplugging the computer.
8helpful
Frozen screen on kindle
Try resetting the Kindle. Press and hold the power button for twenty seconds until it turns off. Press and hold the power button for a second or so until it starts to reboot.
Nov 29, 2012 • Cell Phones
2answers
My compaq notebook presario cq50 210us is frozen on a black screen
Try the laptop on an external monitor, if it works ok on that, the fault lies with the laptop screen
If it does not work on that, the fault is with the graphics chip on the laptop
If it was working ok then suddenly died, check to see if you can boot to safe mode (F8)
repost the results
2helpful
2answers
Itouch is frozen on white screen & wont turn off
Try doing a hard reset: hold the hard buttons for 20 seconds.
Heres a video to see for example.
http://www.youtube.com/watch?v=BuBWoZ0-gNM
1helpful
3answers
When i try to turn on my macbook nothing shows up on the screen and the white light on the bottom right turns on and stays on
Plug the power adapter in. Then hold down the startup button for 15 seconds. The light should go off and then after a few seconds. restart normally. The macbooks have a safety device that will lock up the drive if it detects sudden movements to protect the drive...
Let me know if you're back up and running. KEN
Screen frozen white
Try turning it off with the power button on the screen, then closing it, then plugging it in... (?) That's what I would do if you havent already.
Frozen on warmup
do you mean frozen on acer logos ?
it might be you hdd isnot detected in bios. your hdd might be dead.
Try to remove the hdd and turn on, if it is past acer logo, it's mean your hdd isnot detected and might be dead.
About the button, you can hold power button for 10 seconds, it will turn off.
Laptop won't turn on.
does it work when you plug it into the wall outlet. i need more info.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
