Question about Guess G85675G WristwWatch
Cannot pull out time set button on guess watch
How do i set the ultmost watch. my aunt is almost blind and needs a talking watch.
I looked on their website, and don't see any instructions for any of their watches. Having set a few watches in my day, but having no idea which one you have, try this:
Press and hold the Mode button on the watch, see if the numbers start blinking.
Then set the hurs and minutes with those buttons. Press Mode once quickly again to end setting the time.
My guess is, if it was the same watch type I was looking at that it also has a 4th button that is labeled "talking". Prees that button when she wants to hear the time announced.
Good Luck. If you know the watch model number, I can maybe help you more.
Mar 03, 2011 | Watches
Need an expert on the new minute repeater by campanola, sold one at the retail jewelry store i work at, gentleman wants step-by-step hands on instruction as to the minute repeater function as well as the...
in order to set the repeater chime you need to set the watch and the sub watch to the same time.
This watch has comes with crown in position 0 , if you pull it out one level it becomes position 1 and if you pull it out one more time it is position 2 .
There are 3 buttons on the watch also. The button directly above the crown is button A the button below the crown is button B and the button directly across the crown is button C.
To set time you must first pull out crown to position 2 when the small second hand is at 12 o'clock position and it is stopped.
The mode will also at this time go to 0 and the sub watch second hand( the long second hand with the sun on it ) will also go to 0.
At this time you can just move the crown to set the proper time to the main watch . Now if you press the B button to set the sub watch . Each time you press the B button it will advance one minute hold down the B button and will advance time faster.
Do this to set the sub watch time make sure you watch the am and pm to make sure you are getting the proper time of day.
if the sub watch second hand ( the long second hand) is not aligned to 12 oclock then press the A button keep pressing button or hold it down to go faster until it is aligned at the 12 oclock position
Now push crown in back to 0 position for your time for your watch and sub watch should be set.
Set leap year.
Pull crown to position 1
Press the B button to adjust leap year.
the leap year is set by how many years from the previous leap year it has been . So 2008 was the previous leap year so we will h ave to set leap year at year 2 . The hands of the leap year are connected to the month so you must hold down a and b button or just press the b button to get to year 2 .
once you do that your leap year should be set.
to set the Repeater ( this is a beep from the watch to tell you the time with sound) make sure crown is in 0 position and hold a button for a couple of seconds to activate Reapter.
you can press any other button to end the chime .
also to get to leap year view while crown is in 0 position hold down the b button for 2 seconds . Pushes any button to return to normal calendar.
Oct 16, 2010 | Citizen Campanola Perpetual Calendar...
All functions on my seiko work fine it just will not start.
mcdevito75 here, Your watch should start by pressing the MODE button maybe once or twice or by pulling out the stem as if to set the time and pushing it back in.
Jul 04, 2010 | Seiko 0512037FA Wrist Watch
Pulled out the stop watch button on my daytona before it was prewound and the whole watch has ceased HELP
The stop watch buttons don't pull out. There are 2 pushbuttons. The upper one starts and stops the timing function and the lower button resets the timing function. The crown has three positions: 1st position is for winding, 2nd for date setting and 3d for time setting. Once things are set wind the watch in position one and it should run. If it does not take it to a watchmaker. You don't want to fool around with such a valuable watch.
Apr 22, 2010 | Rolex Daytona 116520 Wrist Watch
How do you change the date on gc watch? product code is I47000G1. Thanks
again, like most other watches, pull the crown to the first position and turn clockwise or anti-clockwise, it depends which movement is inside the watch (in the second position you can set the time)
...shouldn't be so tricky....
Mar 12, 2010 | Guess GC Collection watch
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 11, 2010 | Guess Stainless Steel Chronograph Watch...
How do I change the time on the tissot 1853 touch watch
  1. Locate the screw on the side of the watch face. This screw is what you will use to set the time on your watch. Water-resistant watches have a screw-type crown, and the screw must be turned toward the body (unscrewed) before it can be pulled out for further use. If the watch is not water-resistant, the unscrewing is unnecessary.
  2. 2 Pull the screw gently outward. The screw can be pulled outward in two positions. The first position sets the date and day. Pull the screw out farther (into the second position) to set the time.
  3. 3 Turn the screw either clockwise or counterclockwise to move the minute and hour hands to the desired time. Push the screw all the way in (and turn it away from the body if you have the water-resistant model) when you are finished.
    Digital Watch
  4. 1 Locate the three buttons on the side of the watch face. These are the buttons used to set the time. The top button is the "+" indicator for increasing the numbers. The bottom button is the "-" indicator for decreasing numbers. The center button is to activate the setting mode.
  5. 2 Press the center button in for one second. The watch will beep.
  6. 3 Press the top "+" button for two seconds. After the watch beeps, you can begin setting the time.
  7. 4 Press either the "+" button or the "-" button (depending on whether you want to increase or decrease the numbers) to set the time.
  8. 5 Press the center button when you are finished. The watch will beep. This validates the setting. The seconds will revert to zero.
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
Nov 04, 2009 | Tissot T-Touch T33159851 Wrist Watch
How to start setting my watch?
The middle dial turns counter clockwise and then it has a release. This is the one with the G symbol. after the release you can pull to two lengths and one is for time the other is for date... hope this helps.....
Jan 11, 2009 | Guess GC Collection watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Viceroy sapphire ladies watch instructions
Looking at this watch I believe the lower right button changes the watch between chrono & time. Push that button until the hand in the bottom dial is on time. Then see if the bottom right button pulls out. If it does then this will put the watch in time setting mode. Now push the top right button. This should move the hands around so you can set the time. I hope this works I'm trying to go by what the watch looks like.
Mar 07, 2008 | Watches
Guess G85675G WristwWatch Logo
252 people viewed this question
Top Guess Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Guess Watch Expert? Answer questions, earn points and help others
