Question about Cooper Industries 7503W Decorator Grade Switch, AC Quiet, 3- Way, White
2 switches 1 light. replacing 1 switch (very old romex, no ground,but, NOT KNOB & TUBE) lol, with Cooper"s 7503w. The original switch has 4 conductors and Coopers's has 3 and a ground. I checked continuity on "your" switch" and I would like to check the very old one. Did I purchase the correct Item from You? Sincerely, Kurt kurtsustarsic@yahoo.com
Cooper 7503w is a 3-way switch.
It sounds like you purchased correct switch.
Remember, fixya answers questions about products. We don't sell Cooper wiring devices.
You have a continuity tester which is excellent, because electricians test, they don't guess.
Hopefully you have a voltage tester for testing steps shown below images.
Notice that new switch has 1 dark screw and 2 brass screws.
Dark screw is 'common.'
Brass screws are 'travelers.'
Screws are color-coded so electricians know where to connect wires
If your switch is a 4-way, it will have 4 screws: Notice switch located in middle of 3-way switches has 4 screws.
If old switch is 4-way, then each time switch is flipped, it will reverse travelers on either side of device.
The same is true with a 3-way switch. Each time switch is flipped, the travelers are reversed.
So a 4-way switch can be used as a 3-way switch, so old switch might be 4-way switch substituted for 3-way.
The key is testing wires in your box.
You have two switches that control same light. Switch1 and switch2.
Switch1 is still installed. Move switch1 to DOWN position.
You are replacing switch2 and have unknown wires at that location.
Switch1 is DOWN position.
Separate wires for testing.
Turn power ON.
Test each wire against each other wire and against metal box to find Hot wire with power. Mark this wire.
Move switch 1 to UP position, and test wires again to find Hot wire.
If same wire is Hot each time, then that wire connects to dark-colored screw.
If different wire is Hot each time, then these are the travelers and these wires connect to brass colored screws in either order. The final wire connects to dark screw.
Now if you have additional wire, that could be wire going to next receptacle.
Leave this wire disconnected and check nearby boxes for power.
If this is a power wire that advance power to next receptacle, it probably connects to dark screw.
Again, you should test, and use process of elimination until each wire is identified.
Posted on Dec 31, 2010
I have four wires; 2 black and 2 white. I need to know how to wire 274w.
The 2 whites from the Romex cable go together along with a jumper. Now, the neutral jumper from the white bundle goes to the SILVER screw terminal one the side of the outlet where the LONGER slot is.
The black wire (load/light side), goes to the brass screw terminal on the SAME side outlet.
The OTHER black (line/HOT) wire goes to the opposite side of the switch, the side that has the connecting tab.
The grounding wires go together and then get connected to the box ground.
Feb 02, 2011 | Cooper Industries Cooper Wiring 274W...
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box...
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Jul 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
Feb 14, 2010 | Cooper Industries Cooper Wiring 2158V 3...
I want to put a switch on a existing light that has a power source from the main panel then carrys on to other wall receptacles.i just want the light to go on and off with the switch, not the receptacles.
there is a simple way and a not so simple solution, the simple solution is to take down the light fixture and replace with a pull chain fixture. I would have to know the building type commercial ...residential...is it hard piped and so on. In a residential setting the solution would be to install a piece of 14-2 romex between the fixture and the switch. 14-2 with ground is a flat cable with 3 wires (2 insulated and 1 bare). do not attempt with the power source on. the white insulated wire should be connected to the black wire in the fixture box, the other end of the white wire in your new piece of romex should be attached to one pole of the switch. the black wire in your new piece of romex should be attached to the black wire or gold screw of your fixture and the other end of your wire should be attached to the other pole of your switch. Now the other wire(the bare ground)if not attached will not affect the operation of the switch or light, but it is a safety which should be installed. all grounds should be connected to insure that any faulty wiring will trip the breaker saving anyone from getting shocked.
Dec 21, 2009 | Cooper Industries Cooper Wiring 2158V 3...
Wiring dimmer to knob and tube
You should attach the green grounding wire to the metal box using a green grounding screw. You don't want to leave the wire loose, as any contact with the switch screws could cause a short.
Also, you should wrap the switch with at least 2-3 complete wraps of electrical tape to prevent the screws from contacting the sides of the wall box.
As a side note, you should likely have a complete check done on your house if you still have knob and tube wiring installed, as the dangers associated with this very old wiring are many. Typically, older K&T wiring was used in homes well over 60 years ago and houses then only had minimal electric current drawing devices, such as lights and a couple of other small appliance devices (toasters, coffee pot, TV and radio, etc.)
The problem with older homes with K&T wiring still in use, is that the circuits can be easily overloaded with modern electric convinences and lead to a possible fire situation, especially since there is no dedicated ground to help mitigate short circuits, etc. Also, the rubber based insulation used on this type of wiring deteriorates after 40 years (+/-) and rodents tend to chew on exposed wires in attics and crawl spaces.
I don't wish to alarm anyone, but as a Licensed Master Electrician, I've seen and done my share of repair work involving Knob & Tube wiring and even had a couple of homes that had a mix of it and other, newer wiring, that I've completely rewired. Many states require K&N wiring be replaced before a home can be sold, so getting a jump on it will make your home safer and better suited to operate all the devices that people tend to have, in today's society.
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Subpanel feeder
Run 1 1/2" to 2" gray pvc conduit.
Mar 30, 2009 | Cooper Wiring Devices INC #BP4404V IVY...
Cooper Industries 7503W Decorator Grade Switch, AC Quiet, 3- Way, White Logo
953 people viewed this question
Top Cooper Industries Electrical Supplies Experts
john h
AJMAL KHAN
Gene Haynes
Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
