Question about BenQ FP767 17" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
I have a BenQ FP767 Monitor when I hook up the power supply and press the button to turn it on nothing happens the light does not come on nor does the screen, i have it taken apart right now the fuse is ok and it is getting juice and all the connections and wires seem to be in place and hooked up. I have no other idea of what can be wrong any suggestions?
  • 5 Answers
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Posted on Jul 19, 2008
Chek if you see pictures on the screen with a lamp 60 watts.If so replace the back light 10.00 + transportation
Posted on Jul 18, 2008
  • 220 Answers
Check the key switches ,They maybe leaky-Replace.
Posted on Jul 08, 2008
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
My monitor will not turn of after a press the off button. Furthermore, none of the monitor buttons seems to be working.
You may have bad power supply due to bad DC filter caps, taht will be th first place to check, post back what you find for further help.
Failed TV and monitors:
Capacitors kit: he can make you a set of caps for you.
Aug 29, 2010 | BenQ 22" G2200w LCD Monitor
Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Apr 08, 2010 | BenQ E2200HD Monitor
Won't power up. Press power button, turns green then orange.
Good day sir/maam, Hi, If the LCD is under warranty, use it, they will replace the LCD monitor for free. If not, you may need spend for a Power supply board, to repair one.
There are two boards usually found on an LCD monitor, one main board that controls the LCD screen, back light, inverter, controls and sound. the second board is the power supply board, which accepts mains voltages 90v-240v AC and convert them to DC to power the entire monitor.
If however you may bring it to a repair shop or dealer, they will replace the power board, and there you go. the monitor is done.
Nov 24, 2009 | BenQ FP737S-D 17" LCD Monitor
On pressing the power button on the front of the monitor. The button lights up then imediatly turns off. I tried the monitor on another computer with the same results.
The monitor is going bad. There are parts on the power supply board which are failing. You can send it to a company like mine or take it to a local repair person. See my website.
Aug 05, 2009 | BenQ FP567s 15" LCD Monitor
BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Nov 01, 2008 | BenQ FP91G+ 19" LCD Monitor
Monitor not turn on when hooked up to power supply only
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Nec LCD1720M
Replace the bulging caps:
C 701; 1000UF @ 35V
C 704; 1000UF @ 16V
other caps that may test weak and should be replaced are:
C727; 47UF @ 25V
C613; 10UF @ 50V
Jan 13, 2008 | BenQ FP737S-D 17" LCD Monitor
Comp won't start
Sounds like the pc power supply is bad... U can replace it, but if supply went out it may have damaged the motherboard. In future, have monitor blank off automaticlly and install UPS to supply pc. HP has histroy of weak power supplies.
Dec 09, 2007 | Computers & Internet
BenQ FP767 17" LCD Monitor Logo
1,440 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
