Question about Polar CS600 Cycling Computer/Heart Rate Monitor
Settings mode is locked how do i unlock it - Polar CS600 Cycling Computer/Heart Rate Monitor
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
New battery installed in 05 Solara, passenger door does not unlock when car put in park. How do I fix this?
When the battery is disconnected, the ADL mode returns to the default setting (Mode A). The following procedure must be used to set the ADL function to Mode B whenever the battery has been disconnected.
Initialization Procedure
Perform the following procedure to initialize the ADL function to Mode B.
1. Move the shift lever into the "P" position and close all doors. 2. Turn the ignition switch to the "ON" position. 3. Within 10 seconds after the ignition switch is turned to the "ON" position, push and hold the rear side (unlock position) of the door lock switch for 5 seconds. 4. All doors will automatically lock and unlock when you release the power door lock switch. ^ This indicates that the ADL function is set to Mode B. If all doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting from step 1.
Sep 11, 2009 | 2005 Toyota Camry Solara
Need owners manual for coleman 455 BEACH GR spa. my control panel is locked out and dont know how to unlock it
Here's what worked for me
Press and hold the following three buttons in sequence: PROGRAM - MODE - SET DOWN. Once all three are being held down, the lock symbol will disappear; and the control functions are unlocked. =0 )
Jun 14, 2009 | Coleman Sport & Outdoor - Others
How do I reprogram the 2004 Pontiac Vibe key fob?
To begin programming, follow the procedure.
  1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
  2. Insert and remove the key from the ignition switch twice within 5 seconds.
  3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
  4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
  5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
  6. Remove the ignition key from the key cylinder.
  7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
  8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
  9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Jun 11, 2009 | 2003 Pontiac Vibe
The battery in my 2006 pontiac vibe went dead. I recharged it; however, the setting for the door locks changed. It now unlocks automatically when I turn the car off instead of when I put the car in park. I...
The 2006 Vibe no longer has that feature. It was discontinued after 2005. I have the 2005 so I know how to change it. If your 2006 is able to change then here are the directions from my 2005.
Programmable Automatic
Door Locks
If you have an automatic transaxle, your vehicle is equipped with an auto door lock/unlock feature which enables you to program your power door locks.
Your vehicle left the factory programmed to Mode 4.
The following is a list of the available programming options:
Mode 1: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. There is no automatic door unlocking.
Mode 2: No automatic door locking or unlocking.
Mode 3: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. All doors and liftgate unlock when the shift lever is moved to PARK (P) with the ignition on.
Mode 4: All doors and liftgate lock when the shift lever is moved out of PARK (P) with the ignition on and all doors and liftgate closed. All doors and liftgate unlock when the ignition switch is turned from ON to ACC or to LOCK.
To change the mode you are in, do the following:
1. Set the interior lamp control dial to the door position.
See Interior Lamps Control on page 3-16.
2. Move the shift lever into PARK (P) and close all doors and liftgate.
3. Turn the ignition to ON.
4. Within five seconds after the ignition is turned to ON, press and hold the power door lock switch in
the lock position for about five seconds.
5. The interior lamp will flash to indicate that the mode has been changed. For example, if the lamp flashes once, the function has been changed to Mode 1.
If the battery is disconnected or run down, the mode is changed to the initial mode which is Mode 4.
Jan 22, 2009 | 2006 Pontiac Vibe
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Unlock
Yes re-installing the firmware, it costs only about 5 bucks on small cell phone shops . it's called flashing the phone .
Aug 28, 2007 | LG VX8100 Cellular Phone
Polar CS600 Cycling Computer/Heart Rate Monitor Logo
854 people viewed this question
Top Polar Scuba Diving & Snorkeling Experts
ray gallant
Bill Boyd
Are you a Polar Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
