Question about Zebra Z6M Plus Thermal Label Printer
How can i print cyrillic fonts with Zebra z6 m plus printer ?
5 Suggested Answers
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
  • 6 Answers
SOURCE: Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Posted on Sep 25, 2008
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
ohms
  • 1879 Answers
SOURCE: "Generic / Text Only" driver printer and cyrillic
Unfortunately printing Cyrillic(Russian) is driver dependent and your application can only use generic/text driver.
Posted on Feb 26, 2009
How ot change the font size, printed on QL320 plus Zebra printer
Contact Zebra Technical Support Phone: +1 877 275 9327
Fax: +1 847 913 2578
Kiosk Only: +1 866 322 5202
**Best Option will be to call them since it is a mobile printer**
Mar 10, 2011 | Zebra QL 320 Thermal Printer
How can I print cirillic letters with Zebra 170 Xi II printer?
Yes this is possible. The PN# is G46999-0801 for Cyrillic Font CG Times.
Oct 14, 2010 | Zebra 170Xi II Thermal Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
I have two zebra printers 140XIIII Plus. Printing labels from the same database file. One prints the characters in boold the other one doesn't. Is this because of the driver? How can I make the two...
You would have to look at the Zebra programming language(ZPL) being sent to the printer. Are you writing your own code or using a labeling software package ? The printer driver will convert to ZPL if using a labeling software package. You didn't say if the two printers are connected to the same PC or two PC's. Check your formats if two PC's. Something else is going on if both printers are connected to the same PC.
Apr 27, 2010 | Zebra 140XiIIIPlus Label Printer
Slow printing problem
Take a look at your label design. If you have a lot of text fields using true-type fonts or graphics, this can result in a delay before printing. The font info has to be sent to the printer before printing. If this is the case, change the fonts to an "internal zebra font". These are fonts that reside in the firmware of the printer and result in much faster throughput. The fonts are usually listed in the software and/or printer driver you're using.
Hope that helps !
Apr 21, 2010 | Zebra LP 2844 Thermal Printer
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Zebra printer 140xilll - Too many print jobs?
It does sound like you have a memory overload when you send the 2nd print job. Each label is getting sent to the printer and filling up the memory. Make sure you are using the printer resident fonts and not a regular windows font. The windows fonts get sent down as graphics and take up memory. What zebra is saying to do is store the format of the label in the printer memory and then just send down the information that changes. For example if you were printing a UPS label the basic format of the label is the same but things such as the addresses and tracking # would change.
Jun 23, 2009 | Zebra 140XiIII Plus Thermal Label Printer
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Apr 06, 2009 | Datamax Prodigy Plus Thermal Printer
HI Les1810,
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra zm400
connect the printer to a desktop or laptop using LPT1.
Jul 10, 2008 | Zebra 203DPI Printer
Zebra Z6M Plus Thermal Label Printer Logo
596 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
