Question about Microwave Ovens
I want to buy a replacement KETTLE only, for my black, RH Quick 2 Boil Kettle, any suggestions. Nick
    Brigadier General:
  • 8,909 Answers
I would contact Russel Hobbs and see if they actually sell them separately. When you are online to them there should be available, a list of retailers that stock the item you want http://www.amazon.co.uk/Russell-Hobbs-15198-Quick-2-Boil-Kettle/dp/B003DNSQPC
I see what you mean, it is part of a set. I bought one, in dark grey, and I am sure they sold one in black, from Wilkinsons. It was Quick Boil Kettle only, on a standard connector stand. TJ Hughes also stock them!
Hope that helps.
Posted on Dec 30, 2010
Kettle is noisy. How do I descale?
There are some descaler solutions available that can be bought at supermarkets. After you use any of them please make sure that you fully fill up to the maximum level allowed with water, boil it, drain it (dont use it) twice before it can be used for usual consumption.
You can have a look here http://www.videojug.com/film/how-to-descale-a-kettle
Jun 29, 2011 | Russell Hobbs Microwave Ovens
When you plug in the light comes on but kettle does not boil model no 15075 buxton white
If this is a kettle then sounds like the Element has gone, buy new kettle....
May 03, 2011 | Russell Hobbs Microwave Ovens
My electrical water kettle does not heat water...how to solve the problem?
Check the kettle at another socket to ensure the socket isn't the problem.
Replace the fuse in the plug.
If the power flex is removable from the kettle, check the terminals in the connector havn't become burned.
The chances are that the element may have burned out in the kettle and in this case it probably isn't worth repairing.
Mar 11, 2011 | Sunbeam Microwave Ovens
How do you desalazize kettle?
If by desalazize you mean remove the deposits which build up from the minerals in your tap water, the easiest way to do it is with white vinegar (most vinegar will work but white is best for cleaning).
  1. Fill kettle with a mixture of white vinegar and water (about 50/50 but it doesn't have to be exact) until it covers as much of the deposits as possible.
  2. Heat the kettle until the liquid boils
  3. Let the kettle sit with the liquid in it for 3-6 hours
  4. Empty and Rinse
  5. Fill kettle with regular water, boil, and empty to get rid of any lingering vinegar taste.
If the deposits are especially thick, you may need to repeat steps 1-4 before moving on to step 5.
Mar 01, 2011 | Microwave Ovens
No problem want to know how efficient the quick-2-boil kettle is and if any problems
Pretty cool product. No problems yet. Does what it is supposed to. I would recommend.
Feb 28, 2011 | Russell Hobbs Microwave Ovens
I have a Russell Hobbs kettle which is now leaking. Can it be repaired. It is several years old but still works well.
The coils of Russel Hobbs outrun the shell jar for sure as the corrosion in the kettle would have caused the leak.
The best can be to get the kettle welded with metal, use gas welding to mend up the leak and use a good grinding tool to polish off the suface.
Wash and clean/scrub well to remove all flux /dirt before you use it.
Boil water three times to discard before you use it.
You can continue to use the Hobbs.
Aug 27, 2010 | Microwave Ovens
New kettle leaves a metalic tast to water after boiling.
Try different water. If you use tap water normally, buy a jug of water at the store. The pH may be wrong (particularly if it is too low) and leeching metal from the kettle. Good luck.
Jan 05, 2010 | Microwave Ovens
Microwave Ovens Logo
171 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
