Question about Canon FAX-B840 Plain Paper Bubblejet
What value to set in set ink cnt? - Canon FAX-B840 Plain Paper Bubblejet
  • 42 Answers
At MaybeNow online guides are always there to provide technical support to troubleshoot Canon FAX-B840 Plain Paper Bubblejet Problems which is free of cost. You can also get Canon FAX-B840 Plain Paper Bubblejet, Fax Machines Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Posted on Dec 30, 2010
Waste ink absorber is almost full. What do I do?
  1. enter the service mode by pressing: Menu --->Scan ---> Copy ----> Scan
  2. select NVRAM ACCES and choose ok
  3. Select ABS-Mlevel and set the value equal to zero
  4. select SET Abs- r level : you should set to zero
  5. Power off the printer
Nov 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Cnt find any sound settings
hit menu,go to settings,scroll to sound settings,should be that if u have t-mobile
Oct 17, 2009 | Samsung SGH-G600 Cellular Phone
MP130 Ink waste tank is full how do I empty it
To reset the Waste Ink Counter:---------------------
  • Press Menu----------- Scan -------------- Copy----------- Scan, to enter Service menu.
  • Scroll to option " Service Menu Counter Access ".
  • Press OK.
  • After entering Scroll to " ABS-M DOT COUNT ".
  • Use arrows to reset the value to ZERO.
  • Press Stop or Reset.
Thats the Solution.
To Clean Waste Ink Pads:-----------------------------
  • Open the cover ( the cover you open to replace the catridges ).
  • Locate the Waste Ink Pads which are situated in the or under the Catridge Slider.
  • Dry up Waste Ink Pads ( You should wear Gloves when holding them).
  • Rinse the pads with Alcohol and make them dry.
  • Replace Pads .Then Set them. Make sure they are sitted properly.
Thank you Sir, I hope I helped you. Have a nice day.
Sep 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon IPF 8000 does not recognize ink tank
thre was a part of inks that didn't worked....so there is no problem of the machine but problem of the chip
Apr 15, 2009 | Canon imagePROGRAF iPF8000 Printer
RE:canon Fax B120 ##342 error message
1.) press function then # u reach SERVICE MODE
2.) arrow right until TEST MODE confirm with Start / Enter (green button)
TEST MODE [1] - [8]
3.) press # ... u reach AMI MODE [1] - [*9]
4.) press 7 ... u reach FACULTY [1] - [6]
5.) press 6 ... .u reach LOST INK CHECK...confirm with green button...
u get [1] - [2]....
6.) press 2 u reach SET LOST INK CNT....confirm with green button...
u get LOST INK = 100 (in my case it was 100 ..this was the error..)
7.) press 0 (the digit zero..) confirm with green button...
8.) wait a few seconds....the unplug and reboot....
this worked in my case....
Oct 03, 2008 | Office Equipment & Supplies
Lexmark E340 printer gave error " Replace Fotoconductor" I replaced the fotoconductor, but it still gives the same error
Reset Procedure(s) after putting in new Photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Aug 28, 2008 | Lexmark E340 Laser Printer
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
84 Replace replace photoconductor
Reset Procedure(s)
Dec 17, 2007 | Lexmark E340 Laser Printer
Canon FAX-B840 Plain Paper Bubblejet Logo
76 people viewed this question
old marine
old marine
