Question about HTC HD2 Smartphone
Av always found it difficult pairing my htc hd7 bluetooth with other htc smartphones & other devices
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 181 Answers
The only thing that you can pair a WP7 handset to is a headset, everything else is not supported, hence your problem! There is no fix as this is not a fault but a feature and we are not sure yet whether this feature will be included in further updates. Thanks
Posted on Feb 10, 2011
My htc hd7 does not stop vibrating
its a software problem Hard resetting the device will solve the problem.
Apr 19, 2013 | HTC Touch HD Smartphone
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
I cant pair my htc hd7 with other devices when i use my bluethooth
Turn Bluetooth on by going to Start Screen>All Applications>Settings>Bluetooth.
Once the Bluetooth has been turned on it will then be in both the searching and discoverable mode.
The device will return a list of devices it found during its search. Touch on the item that you want to connect to, enter a pass code, confirm the pass code on the other device and the pairing will be complete.
Mar 22, 2011 | HTC HD7 Cell Phone
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
On my hd7 is there a bluetooth app to send pics
Jan 25, 2011 | HTC HD7 Cell Phone
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
My HTC magic mobile Bluetooth is not working
Hello
What you have to do is to is to open the bluetooth menu on your HTC phone and touch the bluetooth logo to put on the bluetooth radio.
Highlight add a new device,your HTC phone will search for bluetooth device that are within that range and when you see the name of your bluetooth device appear on the screen press next.
Enter the bluetooth device passcode,this can be found in the device owners manual.if the passcode is accepted then press done.The pairing process between your HTC phone and a bluetooth device is complete.
BEST OF LUCK
Jul 06, 2010 | Cell Phones
Does not find device
You must put your headset in pairing mode first (check itsuser guide on how to do it, since you haven't provided any details on its model), and, only then, make your phone's bluetooth application search for new devices.
Hope it works for you.
Just my 2 cents... Carlos
May 24, 2010 | HTC Touch Pro Smartphone
How can i connect HTC P3300 to pc with bluetooth
It's as simple as that.
1. Enable bluetooth on your HTC phone.
2. Tap 'Start' > 'Internet sharing'.
3. From the 'PC connection' drop-down list, seletec 'Bluetooth PAN.'
4. Tap 'Connect'.
5. Enable bluetooth on your computer/laptop.
6. Go to 'Conenction Manager'.
7. Select 'Conenct via bluetooth'.
Both devices will be in sync now enabling you transfer data.
Oct 18, 2009 | HTC P3300 Smartphone
My htc hero pairs but then says paired but not connected. It cannot then be found so i cant send or receive any thing through bluetooth also the phone dosen't connect wirelessly 2 my livebox (orange...
The Hero has a rather crippled Bluetooth which is one of the reasons I'm sending mine back.
For security, when you set the phone to be discoverable it only stays that way for 90 seconds. This cannot be altered unless someone works out how to bypass it with an app but I understand from HTC that this feature is built in at the firmware level.
Look down at the devices list in the Bluetooth menu and you'll see what's paired with the phone; press menu and you'll have the option to connect.
Bluetooth on this phone cannot be used for file transfers of any kind. It's only there to enable connection of devices like headsets and external keyboards and that's about it. You can't even take a photo and Bluetooth it to another phone. There is no way around this at present.
Not connected with your question, but have you discovered the annoyingly expensive and non-alterable trick which it does when you want to send/forward long SMS messages yet?
Oct 07, 2009 | HTC Hero Smartphone
HTC HD2 Smartphone Logo
203 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
