I need a set up manual for my swift network 4G wimax broad band. I misplaced the one that came with it. My modem serial number is 4c5499d67d.
SOURCE: siemens ADSL Modem(model- C2110)
Following is a link where you can get USB modem driver installation guide and driver.......but please make sure that you do not try to install this on SERVICE PACK 3.......because that will not install on service packs.........in case you have service packs for XP installed first uninstall ther service pack........then install the USB modem which is more or less smooth........and you can reinstall service packs afterwards without any conflict later on after the installation is complete.........this is the way I was able to install this modem driver on my PC.......
http://www.calcuttatelephones.com/dataoneinstall/usb09.html
Posted on Sep 21, 2009
  • 163 Answers
SOURCE: I just started using the Clear WiMax Home Internet
yes you need to change the router settings to the present one..
Posted on Dec 22, 2009
  • 10 Answers
SOURCE: How to find Sandisk cruzer 4G USB drive serial
Try using Belarc Advisor with the USB drive plugged in. Read the report to get the serial number. Hope this helps.
Posted on Mar 14, 2010
  • 62 Answers
SOURCE: can we block url using Siemens Networks Residential Router 1600
i don know about the url filtering options in this router. u can try sunbelt firewall . this firewall has url filtering options.
Posted on Jul 22, 2010
SOURCE: Stolen tv, need serial number
I got an Samsung 52 inch stolen along with 2 others 32 inch television, but I called Conn's and they me the serial number where I purchased the television from. This happened in May, but I still have not recovered my televisions.
Posted on Aug 01, 2010
How to set up
In the most simplest form, plug an ethernet cable from the router to your modem, plug in the power then on your computer look for the wireless network most likely starting with netgear and ending in the last few digits of the serial number located on the router.
Jan 31, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
Can we block url using Siemens Networks Residential Router 1600
Jul 22, 2010 | Siemens (120-5830-001) Modem
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
Bought 2nd hand modem to have 2 feeds off the same broad band i alredy have anambit modem, but was hoping to use one for games , the other for pc. i tried to set up modem but although all leds showing...
You can't have two separate modems because of addressing conflicts with your service provider. You can connect one modem only. What you need is a router to allow multiple computers to share the connection. The router presents a single address to your ISP, and assigns its own addresses to the computers you connect.
Visit the site of any router company and they'll have information on setting up your own home network. It's usually a pretty simple process.
Feb 18, 2010 | Arris SURFboard SB4200 Modem
Computer will not reckonise broad band moden
ask you ISP what are the IP address and DNS server address that you need to feed in the properties setting of the TCP/IP setting in the Network Connection wizard in Control Panel
without these the connection will not work
Dec 09, 2009 | Computers & Internet
I got the linksys router problem which no problem at all when i connected to sg broad band . currently use it to connect to malaysia streamys broad band and problem occured. when i connect the router to...
For that you enter in linksys configuration page with 192.68.1.1
then enable dhcp .
Aso set WAN settings as your internet service provider settings.
For that you have to set DNS server and other settings as your malaysia streamys broad band settings.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | Linksys Wireless-G Broadband Router
Broad band connection
we have on type4 modem (zxdsl 531b) how can i connect two pc with this modem
Aug 26, 2009 | Computers & Internet
Linksys wirless G 2.4 broad band router download driver
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 10, 2009 | Linksys Wireless-G WRT54G Router
D-Link DES 1005D
set u r borad band router/modem to dhcp and set both system to auto detect ip address put u r boradband ethernet cable to hub and both pc in same hub that it nothing to do with configure  enjoy!!! need help for router/mode to configure tell me the model number i will tell step by step
Oct 18, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Modem automatically not configured ( Network Adapter)
This happens with almost all the modems and routers. You can try resetting the modem ( you can find the reset button at the back side or underneath the modem ). After the reset, the modem should get auto configured.
Thank you
Apr 29, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
