I have d-link 2+ router520 t with f/w V3 0280T01.ME but the router dis connect many time per houer i check the connector cable also the electricty cable but every thing ok! i thing the poplem in my router it self because the adsl lamp only it is stop plinking thin it back to connection can anay one help ??
raevenzero
  • 53 Answers
SOURCE: Poor connection with Belkin MIMO G+ router
I would honestly suggest a new router. Although, you could check through the settings on your router and see if the wireless signal is lower then 100% for some reason. Also, see if is blocking any ports. A lot of new router's firewalls will lock a lot of ports down if it sees a virus or trojan trying to communicate outward, so do a scan on all of your computers. You can also try holding the reset button on the router for 30 seconds (you will need a pin or something small), then reconfiguring and using it and see if that helps.
You can also go through this website to try and update the software on your router.
http://www.belkin.com/support/article/?lid=en&aid=5947
Posted on Nov 05, 2007
  • 221 Answers
SOURCE: Unplugged per cable company instructions & not won't connect
The configuration of your cables is correct, as long as your modem is connected to the 'internet' port on your router. You must unplug the power cord from the back of your modem and plug it back in so that the modem recognizes the router. After doing this you should be able to get to the internet.
The modem has a security feature that only recognizes one physical address. When you were plugged directly into your pc, it had the pc's physical address saved in its memory. When you reconnected to the router, the modem blocked the router's access to the internet because the physical address of the router did not match the physical address that was saved in memory.
Posted on Apr 13, 2008
Fenla
  • 51 Answers
SOURCE: I cannot connect my xbox 360 to my tp link router(tl-wr6145)
Had this problem my self, try lowering the firewall on your router and make sure the network allows media sharing.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: How to Install DLink DIR-615 with only 1 port on my laptop?
Connect the modem to the router via the ethernet cable. Connect the laptop to the router by means of another ethernet cable in one of the 4 spare sockets. Switch everything off. Turn everything back on one at a time, modem first, then router, then laptop. Allow each unit to fully power up before switching the next one on. Put the installation CD in the laptop and try again. If you are using the laptop wirelessly, make sure the wireless function is switched on!
Posted on Apr 14, 2009
nandini789
  • 430 Answers
SOURCE: a network cable is unplugged
This message " A network connection is unplugged" comes when the connection unavailable may be due to faulty connection. Chek that your router is rightly plugged and the sockets are dust-free. If problem persists, contact support.
Posted on Aug 15, 2009
Testimonial: "Thanks, for the info. I had to call the router people and it is now fixed."
I m getting error on my dir-300 :network cable unplugged" and only power light is indicated. No other lights blinking. What to do? I tried to reset several time but not worth..
1. Make sure the LAN/ Ethernet cable and RJ-45 connectors at both ends of the cable are fine and the cable is not damaged.
2. To identify the problem, try a short cable and another PC/ Laptop
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | D-Link DIR-300 Wireless Router
Hello, Got a D-Link 1005D 5x100 Im having 2 computeres atm, but i cna only get one to work. When i plug the internet cables from the computers to the D-link router, only one can work, please...
Your D-Link is a "switch", not a "router".
So, every computer that you connect will require a _UNIQUE_ IP-address.
However, your account with your Internet Service Provider is only granting you *ONE* IP-address.
Upgrade your account to pay a few dollars more per month, to get additional IP-address(es).
Buy a D-Link Router, for under $50, and connect both computers to the 'LAN' ports,
and connect the 'WAN' port to your cable-modem (or DSL-modem).
Dec 08, 2010 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Changed from DSL, to cable no router connection
1. You need to make sure that you have a "straight through" cable and not a "crossover".
2. the yellow cable that your cable company provided is the cable that goes from the rj45 wall connector to the "WLAN" connector in the back of the router.
If you go to router manufacturers site you will find the instruction how to to connect your router to the cable modem.
3. check also the firmware updates for your router at this site and download.
4.Use your setup disk and follow the instruction set for cable also. This should walk you through the proper setup .
YOu didn't provide the model number of your router, I would have given you the setup site for your particular router.
You can go to D-Link's site and download the PDF instruction also.
May 15, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Had 3 d-link routers that keep giving off the error message that the "network cable is unplugged" all different models at different locations connected to differnt computers any ideas?
Hi, either there is a broken cable or faulty connector some where or the Lan card in your pc is faulty.
1/ Check all cables
2/ start with one router and connect that up by its self, without any other router.Connection should be made as close to the pc. You know the usual setup, modem,router,pc.
We are trying to narrow it down.
If pc still says network cable unplugged then make sure the lan card, in your pc is seated properly.Are you using a seperate lan card or the the motherboard connection.
I have just found that this product was discontinued in 2003,you are probably better of buying a new one.
But any how let me know how you get on.
Regards - Anthony
Jan 07, 2010 | D-Link (DI-711) Router
I have some problem with my D-link Des-1008D switch.I used it to connect 2 computer in my home and one cable form Internet shop.At that time, that Internet shop used manual IP to connect PC.And then That...
Does your ISP supply _one_ or _two_ IP-addresses per account?
On each computer:
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
What "IP-address" and "gateway" do you get for each computer?
No, a "driver" for the switch is not necessary, and will not help.
Instead, buy a "router" (with or without wireless capability), and rewire your network:
Cable-modem -> Ethernet-cable -> WAN-port on router
LAN-port-#1 on router -> Ethernet-cable -> Computer #1
LAN-port-#2 on router -> Ethernet-cable -> Computer #2
Turn the cable-modem off.
Turn the cable-modem on.
Turn the router on, to get one IP-address from your ISP.
Restart each computer, to get new IP-addresses for each computer.
Within the web-browser on each computer, disable "auto detect proxy".
Nov 16, 2009 | D-Link DES 1008D (DES-1008D) 8x10/100 Mbps...
Having problem installin the WRT160N. The cables
You can actually configure your router manually without needing the Setup CD.
You may refer to this link for setting up your router for Cable.
And refer to this link for setting up your router for DSL.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Bought wireless connection still cant connect to internet on wii system Belkin_G_Wireless_9430BF is the namw of the wireless connector can connectwith ps 3 but not wii
does the wii see the router do you have a laptop to make sure its sending a signal try this dis connect everything plug in the modem let it symc up by it self then plug in the router and hook up the cat 5 cable to the router
the try to sync the connection with the wii by searching for the router
it helps to name your router first with a laptop but that should work if not let me know iam a cable tech with a few tricks
Aug 01, 2009 | Nintendo Wii Console
How to connect Nortel BSR222 (Business Secure Router 222) with tplink
rj11 are connectors used to deliver signals to a device. Mostly, modems will be able to support this type of connection. Make use of a modem, bridge it and connect the router to it.
Aug 17, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
After hooking up wireless router model #WRT54G2, all I get is a error code that my either net cable is unplugged when it is connected per installation CD (checked it numerous times) Is my cable defective?
The problem is one of three things. The order of replacement is as follows:
1. Bad Cable
2. Bad Network jack connection
3. Bad router
When items are functioning properly you will have connect LEDs on the network card and the router. Also ensure that you TCP/IP setting are set to obtain an IP address automatically
May 19, 2008 | Computers & Internet
Lights are gone
Well, If You've Had It For Four Years, It Definitely Sounds Like Your Router Has Died So To Speak. Most Routers Only Tend To Last A Few Years Of Being On Constantly. I Would Suggest Buying Another Router Because The Cost Of Repairing This One Really Isn't Worth it. Good Luck, Brodey
Sep 15, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
