Question about Garden
How do i wire in a pair of chamberlain 771e sensors to cb12anz control panel to stop the gates closing when obstructed thankyou
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
venexcsd
  • 1185 Answers
SOURCE: my automatic sliding gate will not close properly
From your description it looks as if the auto detection system needs setting up again
Have a look at
http://www.proforme.co.uk/images/Robus600_1000_EN.pdf
Posted on Jun 25, 2009
  • 3197 Answers
SOURCE: My Chamberlain garage door opener only opens 8 inches.
Sounds like you have broken door springs or a bad drive gear. Take a good look at the springs and then remove the cover and look at the gear. It is white nylon and is just in front of the motor.
Posted on Sep 07, 2009
  • 14 Answers
SOURCE: need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Posted on Mar 14, 2010
  • 3197 Answers
SOURCE: We can't close our garage door
Make sure neither light on the sensors is flickering. Tweak them a bit to make sure they are aligned properly.
Posted on May 17, 2010
Testimonial: "Thank you for the quick response. The lights are not flickering. We can now open with both remotes but cannot close the door with them. We have to us the wall unit. "
Why will my garage door not go down?
Safety sensors! The two sensors on either side of the track of your door. There should be a solid light illuminated on both.Blinking, flickering or absence of light indicates either misalignment, faulty wiring, failing sensors, or interference from the sun. Usually its the first one. You can bend them to realign. If they are not functioning at all, check the wiring connections. If all else fails, replacement of the sensors is necessary.
Apr 25, 2014 | Building Materials
Liftmaster chamberlain professional 771E-03 infrared sensor - have these on my gate system and operate it with a button system - was told sensors needed replaced - have done this but the one button keypad...
Why don't you try contacting Chamberlain? The information is below but you need to get the model number of your system. The number you give must be a part number of some kind.
support@chamberlain.com, or call toll free Technical Support Hotline at (800) 528-5880
Aug 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
My elite gate won't close. the charge ok led light is not on. checked everything and it's ok. switch limit switch on both sides works fine except when trying to close, it won't run.
If you disengage the motor does the gate slide easily? if not that could be the problem, most gate control boards have a sensor that detects the current drawn by the motor, if the gate hits an obstruction or is jammed the motor draws more current and the sensor stops the gate moving. It could also be a problem with the safety sensor, to check this locate the safety sensor input on the control panel and bridge the 2 contacts if the gate then works the safety sensor is the problem.
Dec 28, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Garage Door opens with remotes but does not close with the remotes
Clear any obstruction from between the safety sensors. Loose leaves, trash, and dirt on the lens of the sensor itself are all examples of things that can obstruct the sensor's signal.
  1. Check each sensor for a steady glowing indicator light. If both indicator lights are on, or if one indicator light is flickering, the sensors may be slightly misaligned. To check for misalignment; obstruct the beam of the sensors so that they cannot see each other. When the beam is blocked, the indicator light on one of the two sensors will temporarily go out. This is the receiving sensor. Remove the obstruction and loosen the wing nut on the back of the receiving sensor. Adjust the receiving sensor until the green indicator light goes out, if not already out, then realign until the green light is bright and steady, then retighten the wing nut. This usually takes a couple of attempts before it is back in alignment.
  2. If an indicator light is out on one or both sensors, check for a possible loose or shorted wire. Sensor wires are attached to the white and black terminals on the back or side panel of the overhead motor unit. Check that they are securely connected to each terminal. Also check the wires for any breaks, especially anywhere they are spliced together.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open, but will not close
Door won't close without holding the buttom down.
Bypass the sensors one at a time until the obstruction light goes out.
Jul 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
