Question about Toshiba Computers & Internet
I tried to backup my hard drive from my HP laptop onto my toshiba canvio portable hard drive. The back up failed and now i cannot access the previously saved files on the portale drive. When I plug it into the computer it says the drive must be formatted, but i dont want to lose the files that were saved on it. Can I recover them?
    Guru:
  • 443 Answers
Try connecting it to the different computer and it is advised to connect it to the back of the computer and run a clean scan on the portable. Right click on the portable hard drive and explore it.
May be you should run the below software to scan your hard drive and computer as well.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Hope this helps.
Cheers!!
Posted on Dec 30, 2010
Can't rename my canvio 3tb hard drive
Check to see if there is a file in the root directory called "autorun.inf". (Make sure you can view hidden files.) If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
Sep 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
Grinding sounds from toshiba 500gb usb disk
The drive is failing, backup or copy your files ASAP and replace it.
Aug 04, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
I cant rename my toshiba canvio 3 1tb
Mar 02, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
Rename toshiba external hard drive
Check to see if there is a file in the root directory called "autorun.inf". If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
Mar 19, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
I need to open my Toshiba Canvio portable disk.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/adr/
Aug 16, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
I have a Toshiba Canvio Pocket-Sized 320GB Hard Drives no longer works and I want to know how to open the box and change
(ASP) Asian Power Device Model WA-18G12U functions properly on both of my book HP 160GB and my 1T
FIXYA - Keep the money...
Feb 20, 2011 | Toshiba Canvio Plus 320 GB 2.0 Portable...
How do I reformat my toshiba canvio 500gb external hard drive for my macbook? If I go to disk utility and erase it, wont it erase the backup software as well?
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Dec 25, 2010 | Toshiba Canvio 500 GB USB 20 Portable...
Computers & Internet Logo
166 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
