No internet access when running thru router - Computers & Internet
  • 34 Answers
You need to setup your router. Pls look at router manual. You can also download it online.
Posted on Jul 08, 2008
Cafe world won't run if accessed thru network with internet access but opens using usb wifi/modem. my current work-around is to disable the network connection, plug-in the usb modem and open cafe world...
With the computer connected to your network (I assume it's ethernet?) and browser access to internet working, try uninstalling and re-installing cafe world.
Nov 27, 2017 | Compaq Presario C700T Notebook
How do I access the setup page of this bridge?
wire the bridge into the #1, 2, 3 or 4 port of your router. access the setup page of your router and go to the DHCP client table. Take note of the ip of the bridge.
type the ip address of the bridge in the address bar of your internet browser. then you'll be asked for a username & password for your bridge. ( default UN: & PW: admin ).
hope this helps.
Sep 17, 2010 | Linksys WET610N WirelessN Bridge...
Idon't know what my security code is for my belkin router.
To reset your WiFi password, run the disc that came with the router, or look at the back of the router for instructions on accessing your router thru ethernet cable to reset your password. I suggest trying to run the disc first, because if you change something in the router setup that you shouldn't then you could end up with more problems. If you don't have the disc, then often router manufacturers will put info on the back of the router so that you can gain access. Look for an IP Address (Example: //192.168.2.254) If you find this, then go to a computer that is connected to the router thru the ethernet cable and open up your Internet Explorer, go to the address bar and type in the IP address as it appears on the back of the router. After this it may ask you for a Username and Password. If so, then it also will likely be on the back of the router. Once you gain access to the router's program be careful not to change anything other than the security password. Look for an area labeled Wireless Settings or something similar to that. Once you have reset or changed your wifi password, click Save or Apply if you see that on your screen, then logout of the router's program and close out your Internet Explorer.
Sep 15, 2010 | Computers & Internet
Unable to access internet thru router
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 15, 2010 | D-Link Computers & Internet
I can access the internet thru cable but cannot
Go to router configuration page (http://192.168.1.1) and find in options: Connect to Internet or something similar
Nov 26, 2009 | NetGear WNR2000 Wireless Router
Cannot connect to internet via wireless router
You better reset it to the factory settings and reconfigure
Nov 08, 2009 | NetGear WGR614 Wireless Router
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
Cannot connect when hardwired thru router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 15sec.. after that unplug the router for 15secs then plug it back in..
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1. it will ask u the username and password, by default the username is admin and the password, just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Aug 13, 2009 | Linksys Wireless-N WRT150N Router
Dynes Wireless G Router
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Jan 14, 2008 | Computers & Internet
3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Oct 14, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
