Question about HP Designjet T610 24-in printer InkJet
MESSAGE D'ERREUR 21:13 ERREUR AU DEMARRAGE DE L'IMPRIMANTE.
4 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Bonjour, je vient de m'acheter
Vous devez retourner à l'emplacement de puissances en chevaux et télécharger les conducteurs aussi bien que l'autre logiciel encore. réinstallez-les… remise à zéro et voyez comment elle disparaît Robert
Posted on Aug 29, 2008
mariolands
  • 2296 Answers
SOURCE: MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 18, 2011
fanaudi
  • 1381 Answers
SOURCE: bjr, j'ai une imprimante canon MP
Salut anna14029
Diverses solutions sont proposees ici : http://fix-your-printer.blogspot.com/2009/06/error-code-6a80-on-canon-printers.html .
Je reste a ta dispo notamment pour les traductions , si necessaire .
Cordialement ,
fanaudi
Posted on Aug 11, 2011
Comment resoudre le probleme suivant:121.07 service engine error
Consult le manuel de ton imprimante. Il doit contenir une section intitul?e En cas de probl?mes.
Oct 10, 2015 | Lexmark Office Equipment & Supplies
Erreur 3C10
The 3XX code -fan abnormality.
Feb 01, 2013 | Konica Minolta magicolor 1690MF All-In-One...
BONJOUR JE POSSEDE UNE IMPRIMANTE LASER COULEUR SAMSUNG ELLE NE FONCTIONNE PLUS ET AFFICHE UN MESSAGE D ERREUR SYSTEM ERROR CYCLE POWER QUE PUIS JE FAIRE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Aug 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Les deux voyants papier et point d'exclamation clignotes sans repture. salutations
Yat-il un code d'erreur que vous avez trouv?? Le code d'erreur indique un probl?me sp?cifique de l'imprimante, s'il vous pla?t v?rifier et de nous le faire savoir, nous serons heureux de vous aider.
Pour toute assistance suppl?mentaire, s'il vous pla?t contactez le Support technique Lexmark
Jan 30, 2011 | Lexmark E232 Laser Printer
Dando erro de SERVICE FUSOR ERROR
S'il vous plaît essayez d'éteindre l'imprimante pendant au moins 30 secondes.
Assurez-vous que l'imprimante est connectée à la prise d'alimentation correcte. Vérifier l'étiquette énergie sur le dos de l'imprimante pour voir si elle fonctionne sur une source 110 ou 220 volts. Vérifiez que la prise d'alimentation correspond à sa tension nominale de travail
Pour plus d'assistance s'il vous plaît contactez le support technique de Lexmark.
Jan 06, 2011 | Lexmark X642e All-In-One Laser Printer
ERREUR FDC FAILURE
FDC == Floppy Disk Controller
The FDC controls the 3.5-inch diskette drive.
Check that the drive is getting electrical power,
and that the ribbon-cable from the motherboard is connected to the drive.
Or, press F1 to enter BIOS SETUP, and select "disable" to block all usage of the 3.5-inch diskette-drive.
Oct 23, 2009 | Computers & Internet
Un ecran blanc au demarrage
Il vous aidera plus si vous écrivez le problème aussi en anglais. Pourquoi limiter le rayon de gens qui peuvent vous aider à seulement ceux qui parlent français? (Québec et la France). En anglais c'est presque tout le monde!
Jul 11, 2008 | Acer AL1916W 19" LCD Monitor
HP Designjet T610 24-in printer InkJet Logo
139 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
