Question about JVC Televison & Video
I have problem switch on problem my model is AV29sx77 and his serial no is 16283710. i call one tv mechanic he told he want change IC - TDA 12073H/N1Fo1 where i get this ic? I am living in chennai ( tamil nadu ) India.
    Brigadier General:
  • 8,909 Answers
Here is a supplier.
http://www.chinaicmart.com/series-TDA/TDA12073H-N1F3F.html
I doubt it is faulty, but it might be. Why have you got to buy it? why doesn't the technician get it if he says it is faulty?
Hope that helps.
Posted on Dec 30, 2010
Tda 9370
Check the video output RGB out terminals of the TDA9370. Check the voltages. If can, check signal waveform. You have't specified nothing about the audio status. If you wish to get the schematic of TVs, using TDA9370, check the site linked here. Never confirm that the IC is OK. Check the serial data & serial clock. Replace the main system control memory IC, too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 21, 2013 | Televison & Video
TDA-1082 IC for TV Model KV-2782AEB is not available in Pakistan
This number IC is not available in India too. There is no manufacturer produces this IC now.
Jun 17, 2013 | Sony Televison & Video
DeawooTV Model DTC 2975 I want to know about vertical ic number.b,cos i can't fine out the number that ic is burn.
Hello
There are two mumbers used in Dawoo tv as vertical IC.
If used is a [9] pin one number is [TDA 8357J].
If used is a [10] pin one, number is [ LA 7848]
OK.
Jan 05, 2011 | Daewoo Televison & Video
My LG TV Model 21FD2RG-AX have problem vertical failure its IC TDA 9340PS/N3/A/1923 vertical out put section ok
replace the vertical ic or check waveform of input signal to the vertical ic from processor, if these all are OK, check the deflection yoke continuity and replace if there have problem
Oct 17, 2010 | LG Televison & Video
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
TDA 8364
Look it up at nteinc.net
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Televison & Video Logo
87 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
