Question about Duke E101-G Gas Single Oven
I have a duke e101-g oven and I want to convert it to propane what should I get?
    Sergeant:
  • 223 Answers
Generally, when you wish to change the fuel for a gas appliance all you have to do is change the orifice. Most appliance dealers will be happy to order a LP orifice for your oven for you.
lp
Posted on Dec 30, 2010
Why would a duke E101-G will sometimes work fine and sometimes dont I replaced the thermostat but it is doing the same thing
When you have a high end oven like this you will find that the manufacture stands behind it. try to find a 1800 number and talk to parts. they will probably want you to talk to an approve alliance repair person but if you ask the right questions and listen between the lines you might find out what you need to know to fix it.
Dec 10, 2014 | Duke Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
How difficult is it to adapt a new kenmore oven from gas to propane?
Hello, W/D here.
It might be even easier than you think! In some areas, propane vendors will convert your stove over for free. If not, they will (the major local companies) have the necessary orifices, and will gladly assist you in making the swap. Try them first, then kick back with a lemonade while they do the work! (I just hope that they WILL do it for you!) If not, like I said, they'll have the materials. I used our local propane company to convert a grill from NatGas to propane, and they had everything I needed, and offered to do it for me. Plenty of free support from them.
Best regards, --W/D--
Feb 23, 2011 | Kenmore Ovens
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
I have a defective flame sensor on a duke oven, I need to know the best way to remove it to replace with a new one. It does not appeear there is enough room inside to access it.
it does require removal of entire burner assembly. which is not all that hard to do but a bit time consuming. fittings for 2 burners and pilot must be disconnected and 3 screws on front of burner assembly. unit will then pull right out allowing access to flame sensor bulb. hope this helps!
Apr 22, 2010 | Duke E101-G Gas Single Oven
Natural gas to propane?
You have to get a converter for propane. You can call any hardware store in your area. Hope this helps you, if not, you can call me. :>)
Aug 13, 2009 | Maytag Ovens
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Duke E101-G Gas Single Oven Logo
277 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Duke Oven Expert? Answer questions, earn points and help others
