the anti slip braking is coming on is controlled by the out side air temp sensor. when the temp is around 5c to 0c it will come on it advances the abs. and drive. if your out side temp sensor is giving a false reading then it will keep coming on and off.
It's the ice risk warning star symbole (*) flashing on the dashboard when outside temperature turn to 39 F. It's normal, and nothing wrong with the car. Just drive carefully!
Hi I will try to solve your problem. power on by the eject button tray should open fully if it goes back in by itself then its the belt that is on the motor you can see it sometimes when the faceplate is off if it does this as it is opening give it a helping hand to come out fully and visaversa going in also if you have an aftermarket faceplate on it the chrome or white facia on the tray interfears with it closing just take that bit off (carefully dont break it) if its the belt problem give me the thumbs up then I will know to post how to fix it easyily
If you connect a laptop projector or external monitor before you boot up your laptop, the video most likely will go directly to that external device. To have both the laptop LCD and projector you will need to press the Function key that has the monitor/laptop symbole (this key will be a dual function key and you will need to press the Fn key first and then the Function key with the monitor/laptop symbole. This Function can be any key between F3 and F12, it depends on the brand of the laptop.
When you press this key it will toggle between
LCD only
External monitor/projector only
or both LCD and external monitor/projector
