Question about Kitchen Ranges
The door is locked and a message says operator 3 keeps blinking and can't finalize the wash or open the window
  • 1 more comment
  • badhabitsau Dec 31, 2010
    Thanks for getting back to me. There seems to be a slight problem in the details at your end ?
    The questions I asked related to a DEAWOO. Front loading cloths washer "latest model" ? It appears to be stuck in between cycles or something? The door lock is on "permanently" and an error message "NO. 03 " flickers on and off. Worked great for three previous washes then all of a sudden it's all locked up and wont finish or open....I have turned it off (both power at wall and off button) "like a computer type of thing" but when turned on again still has the same problem? Is there a reset button or something or is it totally stuffed ? ;) Thanks
    HI...here are the details DAEWOO DC
    AIR POWER DWD F1222 FRONT LOADING WASHING MACHINE 7KG-1200RPM. THANKS ;)
  • badhabitsau Jan 01, 2011
    yes....I sent you the full details on the model number etc. why isn't any of that here?
  • 1,998 Answers
Please provide make model number and what this appliance is that your having a problem with and any further questions that you may have thanks again
Rick
Posted on Dec 31, 2010
  • 2 more comments
  • Rick Ead
    Rick Ead Dec 31, 2010
    do you have a model number to your daewoo? or do you have a manaul without a model number i am unable to look up anything and you would have to use your manual which it would or should also say what that error code is as well message me back with your model number with a model number i am able to provide videos and diagrams like this one http://www.geappliances.com/videos-media... thanks again rick
  • Rick Ead
    also for a washer you can remove the bottom panel im assuming it is a front load washer when your remove the front panel if you reach up on the right side you will feel a pull cord if you pull the pull cord the door will openThanks again
    Rick
  • Rick Ead
    take off the two screws on the lower panel as well as the screw that is inside the pump clean out door you should see the pull lever to open your door I am still researching the no3 error code . This is what the exact machine message says correct?Thanks again Rick
  • Rick Ead
    Rick Ead Jan 01, 2011
    because daewoo doesnt make videos and such like ge or whirlpool or most any other appliance company does have you removed the lower panel and pulled the cord that goes to the door lock assembly?I await your reply Thanks again
    Rick
LG Intellowasher WD-8026C having problems with the door latch, I keep getting an error message. Latch appears not to be connecting and locking the door. to start the machine.
The DE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Jan 31, 2015 | LG Washing Machines
My LG washing machine is displaying DE when I go to start it and it beeps and blinks de
The DE error or fault code is to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Sep 21, 2014 | LG Washing Machines
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Keeps flashing f26 fault
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Dec 24, 2010 | Whirlpool Washing Machines
The button on wall which has a little green lite in the center, keeps blinking, but the garage door does open
Press and hold the lock button for 3 seconds to stop the light from blinking. That blinking is the indication that the lock function is on and your remotes will not work.
May 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
Door locked
You cld try 3 things:
1 Find the button on your panel which has the 'key' symbol, press and hold this down till the lock light goes off.
2 Hold down 'options' & 'select' buttons together till the light goes off.
3 Press 'end of cycle' button for 3 seconds, lock should come off.
Pl post back results. Rate if helped.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
