Question about Samsung SyncMaster 920N 19" LCD Monitor
I have a Samsung Synchmaster 920N monitor. It was working perfectly till last night. Today when I switched it on, the screen stays blank (unlit). The ON indicator on monitor flashes at about once per second. When the signal cable is disconnected from computer it DOES NOT SHOW NO SIGNAL. I have tried connecting it to another computer, but same symptoms stay. Please help.
I have exactly the same problem with the same monitor.
And I have no solution. Please help.Thank you
Posted on Jan 06, 2011
The screen of the monitor is blank. The green power light though is flashing. I can hear a faint ticking sound from within the monitor. It is as if the backlight has just failed. The monitor have been...
The flashing power button is an indication that the power supply has failed. There are parts called capacitors that filter the output power and when they short out the power supply can't start up correctly os it tried over and over, this make the power light flash each time it tries to start up. The monitor is easy to repair if you can do a little soldering. Here is a link to a repair guide that will show you how to dis-assemble the unit and what to look for and replace to get it back going again. Te guide also has videos showing the steps.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 10, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
Power on/off not respond, what can i do ? my screen Samsung SyncMaster 920N
This may due to power supply is not connected properly or power supply itself gone bad. check and repair/replace the power supply may solve your problem.
Revert back for assistance.
Jan 20, 2010 | Samsung SyncMaster 920N 19" LCD Monitor
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Blank screen
Hi!
A simple test is to connect another working monitor, to figure out if the problem is at cable connection or at graphics card 's output, and replace properly.
good luck!
Dec 26, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Shadow on screen
hello
yes this is the problem due to dry sold or bad ic presuent. plz call a hardware engineer to check the problem
thanks
ramesh
Dec 01, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
Blank screen
1 Blank - absolutly or 2 stuff on the screen but dim and unlit? 1. - tube or inverter gone - workshop job 2 Ditto
May 30, 2007 | Compaq Armada M700 Notebook
Samsung SyncMaster 920N 19" LCD Monitor Logo
268 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
