Question about Garden
I want to but a 3 HP Baldor 220 motor on my 10" craftsman table saw. Will the motor mount be able to stand the stress of a heavier motor without pulling the arbor out of square with the table?
    Brigadier General:
  • 4,088 Answers
A 1/2-horsepower motor wired for 220 volt operation is ample for this hand-fed saw. Using a much larger motor will lead to some serious kick-back problems because the motor will continue to turn if the cut becomes bound. A higher horsepower motor requires power feed for the stock to control kick-back. Hope this helps!
Posted on Dec 30, 2010
  • bbgb17 Dec 30, 2010
    I haven't had a board kick back on me in about twenty years, (knock on wood...pardon the pun) I use a 5 horse Powermatic at work everyday. I guess I've just gotten good at not doing risky things on the saw. They gave me this particular motor at work. It was free! I want to use it if it won't pull the arbor out of square. Surely somebody out there has tried to soup up a Craftsman saw. Is the Vega fence worth the money?
  • drallim Dec 30, 2010
    I worked in the cabinet shop of a trailer plant in the early 60's and they had a 5 HP Powermatic that was notorious for kick-back. I used it a few times without problems, but no one ever made serious use of it.! I also have a 60's era Craftsman 10" saw that is all cast iron, but it seems somewhat flimsy in spite of that. The stock fence is almost impossible to get consistent settings due to it's design. Hope you have success with your projected modification.
How do i replace a 230v tablesaw motor
first fin the motor..try Baldor. bring in the old motor so they can match as mounts/rotation are an issue.
Oct 14, 2014 | Metabo TS250 Stand 10 Inch Table Saw with...
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
My 10" Craftsman table saw will not start.
Check to make sure that the power is going though the switch. Check for power at the motor. If there is power going into motor, then the armature is probable shot.
Feb 04, 2010 | Craftsman 10" Table Saw
Want to replace under powered saw motor on sears 10"table saw
u can put a 2 and above if u want just need to have the correct rpms
Jan 26, 2010 | Craftsman 10" Table Saw
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Nov 02, 2009 | Craftsman 10" Table Saw
Switch from 220 to 120 volts on a craftsman model 113.196380 radial arm saw 10''
you need to open up the motor and swap/splice the line wires with the motor leads. contact sears. the diagram should be on the motor housing.
Oct 17, 2009 | Craftsman Saws
Key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Sep 14, 2009 | Craftsman 10" Table Saw
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Jul 18, 2009 | Craftsman 10" Table Saw
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
