Question about Roper RGX4634KQ Gas Dryer
Hello, my dryer is not getting hot. how do i find out whats wrong?
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 30, 2010
I have a Frigidaire Elite dryer (DE7400PW0) that got super hot (inside and out), beeped, and flashed an E6 fault code. Can't find what that means is wrong?
Hello Kari Brchler,
Repairclinic... One of many part houses...
Suggesting possible causes for your
Frigidaire DE7400PW0 Overheating issue:
Watch these video hints:
Frigidaire Dryer Overheating
also see appiancepartspros
http://www.appliancepartspros.com/parts-for-frigidaire-de7400pw0.html
Carnac the Magnificent
May 17, 2017 | Frigidaire Dryers
Hello, my dryer MDE5500AYW won't dry on a cool temperature. It is an electric dryer
You buy no parts
You diagnose the problem
to find something wrong
How about looking in the owners manual
& follow the trouble chart
I do not know about Maytag Dryers, but the washers
have a diagnostic manual in a bag under the cabinet,
they don't want you to find,your dryer may also.
Nov 20, 2014 | Maytag MDE5500AYW Electric Dryer
My electric dryer won't dry clothes. Doesn't get hot, what's wrong with it?
how is the lint filter maybe it is too full of lint and the dryer will not heat up to protect you from burning doen your house when the lint filter gets too hot and catches fire. Just a thought
Oct 28, 2014 | Dryers
My dryer is turning but it isn't getting hot? What
dryer element not getting hot .possibly only 110 volts instead of the needed 220volts ...maybe a bad breaker in fuse box
Nov 29, 2011 | Kenmore Dryers
Hello, Dryer truns but does not get hot. Where should I start?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 14, 2011 | Dryers
Dryer turning but not getting hot, what could be
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
May 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer does not turn off, and now no heat, what could it be?
At first blush, it sounds like the timer failed. Try unplugging the dryer, leave it off for several minutes, plug it back in (or turn the breaker on) and try again.
If it doesn't work, it sounds like the timer.
Mar 15, 2010 | Dryers
Not getting hot
Hello there:
This is a common problem with dryers your heating element has either failed or is not working properly, i would have this checked out by a qualified repair man also you may want to have the unit checked out to make sure that their is nothing else wrong with the unit ok?
best regards michael
Oct 17, 2009 | GE Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Roper RGX4634KQ Gas Dryer Logo
37 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
