Question about Whirlpool LER5636P Electric Dryer
Blower moter fan
How does the fan come off ? I think it spins but i'm not sure and don't want to break, please help
  • 413 Answers
Before attempting to remove blower, run the motor and note the direction of rotation. The blower wheel can be very difficult to remove. It is screwed on to the motor shaft opposite to the motor rotation such that every time the motor starts, the blower wheel gets tighter. The best way to remove, is to put an adjustable wrench on the blower wheel (from the motor side) and using another wrench or locking pliers on the side of the motor shaft where the belt goes. Rotate the motor shaft where the belt goes, in the opposite direction of normal rotation while holding the wrench on the blower wheel. It will be VERY TIGHT. If unsuccessful, the only alternative is to strike the blower wheel REALLY hard and break it off. GOOD LUCK!
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 08, 2008
2002 blower moter will not shut off
I would think it has to be the fan switch on the dash. Give me more info & I'll try to help.
Aug 05, 2014 | 2002 Chevrolet Blazer
The blower fan on my AC/Heater isn't working properly.
check the capacitor on the moter or just replace 12.00 bucks. if it doesnt work you need new moter.
Oct 23, 2012 | General Electric GENERAL ELECTRIC...
Blower motor resistor replacement 1999 chevrolet silverado
posible fan moter bearing or sometimes a foren object falls into the the housing
Nov 29, 2011 | 1999 Chevrolet Silverado 1500
Air conditioner starts up then shuts off after a few minutes. It appears the fan moter is getting extremely hot. The fan spins freely. What could be the problem?
The fan motor getting extremely hot is an almost sure sign of a bad fan motor.
Check Capacitor
if not then you most likely will have to replace the fan motor.
Let a service man decide if your not sure
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Dometic Rooftop RV Air Conditioner
1995 buick roadmaster/heater and ac fan staying on
there is a module that controls the motor located arend the blower moter that will need to be replaced. Not sure if this is available other than dealer. check with auto parts stores first. I would ask for blower motor control module.If this helps please reply and good luck
Apr 27, 2010 | 1995 Buick Roadmaster
Heater fan has stopped blowing. Just before this happened a lound droning/whining noiuse came from front of vehicle.
From you're description I'd say the blower moter has
cooked a bearing. Check fuse #1 and #2 both are 15amp. They're in the fuse block behind the coin tray
on the lower left side of the dash. They usually go first if the bl moter locks up. To do a quick test unplug the bl moter, located behind the right side of
the dash. Turn the fan switch off and replace the fuses. Plug the blower in and turn it on, if it pop's the
fuses again replace the blower moter. Hope this helps.
Mar 21, 2010 | 2003 Subaru Outback
Blower moter won't run blower good
replace the fan resistor located on the side of the heater box under the dash usually on the passenger side this controls the fan motor speed along with the switch itself.
Dec 08, 2009 | 1999 GMC Safari
Rendezvous blower moter stops suddenly
It seems to be the Resistor in between the blower and the wiring.
Apr 05, 2009 | 2003 Buick Rendezvous
Blower fan
it sounds to me like your blower moter resister or your blower moter switch are going bad both are right under the hood next to the blower moter one has 2 witers on it the other has 4 it usuley on the pass side right near the window
Dec 03, 2008 | 2000 Chevrolet Venture
Whirlpool LER5636P Electric Dryer Logo
276 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
