Question about Garden
I need a brake down manual for a victa T 20 whipper snipper carby. its a plastic walbro carby
    Brigadier General:
  • 4,088 Answers
Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. It covers metal-bodied models, but the operation is similar. Hope this helps!
Posted on Dec 30, 2010
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 04, 2016 | whipper snipper Garden
Will not idle
Hi you need to take the carby off for cleaning
Take carby fully apart,
Remove the low & the high adjust screw blow air down all small holes & jets.I had the same problem with a Whipper snipper done this & it fixed it.
Feb 13, 2013 | Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
The carburettor needs an overhaul or replacement.
take carby down to any mower shop ...most brushcutters use same carbys...
Mar 20, 2010 | Homelite Expand - It Brushcutter...
Lawn hornet whipper snipper needs tuning
clean the air filter first of all and then take the spark plug out to make sure its clean (should be a light brown color)
if you need to tune it take the carby cover of and you will find two needles or screws marked H and L wind them both all the way in then wind the H out 1turn/wind the L out 1/2 a turn . this is a good starting point. Start the snipper then adjust the L screw minutely till it revs up quickly and doesnt bog down
Mar 18, 2010 | Ryobi Garden
How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Oct 18, 2008 | Garden
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
