Question about Vacuums
Say some thing about your self?. - Vacuums
  • 784 Answers
Fun and positive -------
c...
Posted on Dec 30, 2010
Can i leave the dyson V7 plugged into the wall socket even after the machine is fully charged?
Best practice is to remove the plug.
In the old days of ni-cad batteries the high rate of self-discharge meant a machine that had to be permanently ready for use had to be left plugged in.
Today lithium batteries are used with a negligible self-discharge and it is neither necessary or desirable to leave them plugged in.
You should of course refer to the instruction manual for a definitive answer.
If the electronic charging circuitry is perfect the charging unit can safely be left plugged in indefinitely, but how many things are perfect...
Dec 28, 2017 | Dyson Vacuums
How to take it apart
Not a safe thing to do your self. take to a repair shop.
Sep 21, 2014 | Vacuums
Can't lower handle on Hoover u6432-900 so can't clean floo
usually theres a plastic pedal you would step on to release the handle.... first thing i would try is pushing up (foreward) on the handle and try pressing the pedal .if the pedal wont push down at all then something might have gotten jammed down in it..... at which point you'd have to do a bit of fiddling around with it to see whats keeping it jammed up.....also... there could be something stuck in there thats keeping the handle from being able to move down.... as for the self propelled part.... it probably wont work untilthe handle is lowered... hope this helps
Nov 12, 2013 | Vacuums
Eureka lightforce 300 poor suction, power paw doesn't spin and self cleaning duster doesn't clean its self when the button is depressed.
When this happens to me I do two things. The first is to empty the cannister but when you do (with the vacuum unplugged) stick your hand up inside of where the cannister goes.Sometimes that is filled with debris. Pull as much as you can out. There is another part inside there that you can twist and pull out - this will help you pull out more of the trapped debris. Replace that part and the cannister - usually there's a blockage and just removing some of that debris will cause a bunch more to dump in to the cannister. You may have to repeat this process two or 3 times untill no more debris comes out when you turn the vacuum back on.
The second tip solution is to clean the filter which can be found on the front of the vacuum.There's a clear plastic cover, a black rectangular this that hold the filter sponge and inside of that, the filter sponge. I just rinse the little sponge inside and shake off the thing that holds the sponge (Sorry, don't know the technical terms). Put it back together and you should have suction - viola.
Hope this helps.
Oct 28, 2012 | Eureka 4718AVZ LightForce 300 Bagless...
Brush will not turn and machine has stop self-propelling forward.
Two things to check out. 1- Any broken belts that need to be replaced? 2- Brush is frozen and needs to be removed, cleaned and lubricated and reassembled.
My guess is there is a problem with the belts.
Oct 04, 2010 | Hoover U8145-900 Savvy Bagless Upright...
My dyson DC07 Hepa will not stand by it self Some
Hi there, I have made a video of the solution to this problem. Just click on the link and follow the instructions. If you need to replace any of your vacuum filters you can find them on vacuumspot or nelsonvacuums both ship worldwide.
Hope this helps!.. And if it did please take the time to leave a message or give it a thumbs up.
Sep 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacumn wont pick anything up and it wont self propel. I checked the belt - it is fine.
There are numerous things to check.
  1. Check for hose clog
  2. Brush belt has many hairs and doesn't move
  3. Brush belt broken/loose
  4. Vaccum bag is full
  5. Height adjustment according to floor.
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propelled function
There are few things that may have gone wrong:
First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears
Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
Sep 10, 2008 | Kirby G4 Bagged Upright Vacuum
Accessing self-propelled cable
The first thing to do is replace the flat belt (38528035), this belt will stretch after a short period, it is the one that drives the drive mech. Also the cable may have broke, if you look down on the right side, you can see the cable, did it break there or is the #34 actuator(#43143046) that the cable attaches to broke. The cable (#43211019)sometimes breaks on the upper end #14, take the handle off and you will be able to tell.
Mar 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
