Question about LG WM2688HWM TROMM SteamWasher
Thermistor for LG WM2688H
Our LG is giving us the te error code again. Can the thermistor be replaced by my husband? Is it a part we can order and take care of ourselves? We live in a small town and can't find an appliance repair place to help us. Really don't want to haul the machine somewhere. Thanks!
treegirl
  • 1 more comment
  • Treegirl Jul 08, 2008
    Thanks! We live in Port Townsend, WA. I'll call LG and see what they say and call some more repair places in nearby bigger towns. I appreciate your help!
  • montylp Aug 21, 2008
    exactly same problem, less than 2 years old.
    Boss lady very upset.
    Lots of $$ for these appliances.
    Larry
  • Treegirl Sep 08, 2008
    Hi Cooltech and guests,
    I found the parts. Ordered the part and the door seal spring clamp removal tool from Andrew's Electronics (800/289-0300) LG wouldn't sell them to me, but gave me the part numbers and Andrew's number. Now, to fix it.
    Anybody have a detailed description to offer on how to get to the part? I did read the one from guest, but would like another description, too, if possible. Do I not need the tool? Do I access it from the bottom of the washer? Any help is appreciated. This is going to be a pain since the dryer is stacked on the washer inside a closet!!
    Thanks a lot!
    treegirl
Thanks so much for the tip regarding flipping the machine on its side. I was about do the lengthy process of disassembling the front and I tipped the machine over instead. Lo and behold, there was the problem in plain sight right away -- the wire to the thermistor had simply come off the connector! I restripped the tip of the wire and crimped it back on the connector, problem solved. Didn't even need a new part!
Posted on Sep 15, 2009
  • 2 more comments
  • Sally Hampton Jan 01, 2013
    What make and model machine do you have? I am thinking it is not an LG Tromm? I have an LG Tromm model # WM2688HWM and when I lifted the front of the machine to look under, there wasn't any accessible area that I could see that wouldn't still require removing the front. from all the diagrams and info I have found, the thermistor on my model is in the front. If you have the same or similar machine, would you mind telling me on which side did you turn it over and exactly where you were able to access this? thanks
  • cyclopaedic Feb 21, 2013
    It's the LG Tromm model # WM2677HWM, not sure if they've changed thing that much. The bottom of the machine is completely open and the themistor curved metal chassis
    I meant to say the thermistor is attached to the curved metal chassis
    By the way that connector is really bad, It has come off several times. After doing this repair four times I have come to a conclusion that the wire is too short, causing tension and pulling on the connector. I have since soldered an extension wire and have not had any further problems.
Yes - repeated tE error solved by simply making sure the connections to the thermistor are tight. I had repeated tE error codes - my wife called service, and when the service man I told him I thought that the tE was a thermistor error...he said "this machine (WM2455HW) doesn't have a thermistor - it is all solid state". It sounded suspicious to me ... and then he "placed his hands on the machine" (claiming that it wouldn't reset by the button combination) and pronounced that we'd need a $290 control board (you can get them for $155 at Sears) and $170 labor + tax.
All of this just didn't make sense to me since 1) a thermistor IS a solid state device, 2) an intermittent problem is RARELY a problem with the solid state electronics (though occasionally, components can overheat and fail intermittently), 3) everything I'd read suggested the tE indicated a thermistor error...and 4) intermittent errors are OFTEN caused just by poor connections on electronic devices.
Well, I dug into the machine, found a thermistor (clearly labeled on the wiring diagram inside the machine), tipped the machine on its back to get access to the thermistor, unplugged the connector to the thermistor and pulled it out of the rubber grommet that anchors it to the wash drum. Then I squeezed the connectors on the female plug end to make a tighter connection and reconnected everything. I then opened the main control board and unplugged all plugs and reconnected them in case there was a bad connection to the main control board.
Guess what - everything works fine now - NO PARTS - and yes, there was a thermistor in the washer (the service man wasn't correct in saying there was no thermistor).
I am concerned that this may be a real scam. Certainly it could be that the service man comes out, says it is a control board, charges for a control board and in fact replaces the board even though it is still good. Taking the old (and new-appearing) control board to the next house where the same claim is made. They can pocket the $290 and the service call.
I probably would not be so cynical about this except for the fact that the service man specifically contradicted what I said about suspecting a thermistor problem and told me specifically that there was no thermistor in this washer (my wife witnessed this).
How can you trust the service folks anyway?
Posted on May 23, 2010
  • 4 Answers
I did the same (flipped on back) but just cleaned and replaced my thermistor...no more "tE" code! It easily pops out and back into place. Very easy!
Posted on Jun 02, 2009
I do not htink its the thermistor, but the connector thats keeps coming loose during use, it only has to break connection for a second. Had the Main board replaced, thermistor and still tE code.. Squeezed the connector with a pair of needle nose and reattached, tE gone.
Posted on Mar 08, 2009
My Thermistor has just went bad also. After pulling the lid and finding it location-to my surprise all I had to do is flip washer on its back, the bottom of the washer cabinet is open and pull the thermistor out it is in rubber grommet and easily pulls out Now I cannot find one to order
Posted on Aug 29, 2008
  • Chadwick Cabic
    Chadwick Cabic Apr 23, 2014
    i got the part at Sears Warehouse.
  • 489 Answers
Treegirl,
It's not an easy job to do.
You will need to remove the top panel, then remove the control panel and then the front panel to gain access to the thermistor.  The part is not available to the public and requires an authorized service tech from LG to take care of this problem.  You will need a special tool to remove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if they can transfer you over to parts.  Just give them the model and serial # and see if they would be willing to sell you the thermistor part.  You will also need the door seal spring clamp removal tool to make the job easier.
What city do you live in??
Good luck.
Posted on Jul 08, 2008
  • clbranco Mar 18, 2011
    how did you crimp the wire. what kind of crimp and crimper? we are having the same problem
    New Friend:
I was getting the same te error on my 4-5 yr old washer. I decided to flip the machine on its back as others suggested. Before doing this, I disconnected the two water hoses and noticed that the hot water hook up was jam packed with sand/sediment. I cleaned out all of the sediment and then proceeded to flip the machine over and have a look. I pulled out the thermistor and everything looked ok with no loose wires. I've just reconnected all of my hoses and started a load of laundry on warm/cold. I am hoping that my problem was caused by the clog in the warm water hook up. I should know shortly.
Posted on Dec 28, 2012
I need to replace the water valve, how do you get the top off
Posted on Jul 29, 2010
Found one through LG distributor is ten bucks
Still getting LE code after replacing Hall Effect Sensor
i would guess you are getting a "tE" error code. that is a bad thermistor. pretty common. and it starts out as an intermittent error. it really is an easy fix. great online videos. check out appliancepartspros.com for both video and parts or repairclinic.com for video and parts. or youtube.com
Feb 22, 2016 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG2487hm washing machine, the geek squad are a bunch of idiots. I have the TE code it only trips off line when the load is heavier than 3 or 4 towels. I looks like it is weight related. right...
TE is a Therrmistor error, The thermistor senses the water temp. As with any error code it could be the part, Wiring Harness or Computer which is causing the issue. If you try cold temp wash the cycles may work. Geeks should OHM out the part to see if that is at fault. LG has 2 different Thermistors. 1. Thermistor is part of the heat element.
2. Thermister is separate. LG part# 6322FR2046C.
Quick easy fix.
Hope this helps.
Mike
Oct 31, 2017 | LG WM2688H Front Load Washer
What is wrong when tE code is displayed?
thermistor error there are 2 in there usually and one needs to be replaced.need service man for this pretty tricky job.
Jan 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
I have a front load LG washing machine. Its two years old and it stopped working today and it is giving a code of TE on the read out. what does this mean? Any help would be greatly appreciated!
TE is a Thermistor error.
This can be a shorted Thermistor and or a bad heater element. These items are located at the front bottom of the washer's tub.
If you have a washer with steam function. It could also be the steam generator's thermistor and or a bad heater element. The steam generator is located just behind the dispenser’s housing on the top left side.
I can get you part numbers is you need them.
Mar 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Te error code
btw...the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error and cleaned it and replaced...no problems since!
Oct 29, 2007 | LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Sep 12, 2007 | LG WM2688H Front Load Washer
Washing Machines Logo
4,419 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
