Question about Peg Perego Vespa Scooter
I have a LML Vespa Select scooter. The problem is that frequently, it does not start even on repeated kicking. I have shown this to many mechanics and most of the times, they end up changing the coil located at the stepney area saying that the coil is week. I have got the coil changed a number of times but the problem is still continuing. Please guide me for this
Simple, just tilt scooter on to the right hand side, for 5 secs and then try kick starting.
Posted on Mar 06, 2011
LML Star 125 Sounds like starter motor turning but not engaging or starting what are the likely problems
Hi, Anonymous the starter drive/Bendix is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day. LML Owners Club Great Britain Forums
Trouble with LML not starting scooters
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial http://iheartstella.com/resources/manuals/stella-4t-service-station-manual.pdf
http://www.modernbuddy.com/pdf/Stella4T_manual-UK.pdf
Mar 14, 2016 | Motorcycles
Gears clunk when change on vespa px 125
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
PX 125 2005 changing gears vespa org uk
Modern Vespa Vespa px125 2005 gear box selector problem
May 22, 2012 | 2005 Vespa PX 125
In my LML Vespa Select II 1996 model, the oil from the engine leaks to the break drum, through the region where the bearing is located. i have changed the oil seal a number of times, but the oil still...
Hi, Richtarzan the seal is not the issue if you are confident that's where the oil is coming from then you have a venting issue or the shaft the seal is riding on is faulty and needs to be replaced.
Good luck and have a wonderful day.
Jun 07, 2017 | Vespa Motorcycles
Auto lube leak on LML from carb box, re which gaskets require replacing ??
Probably best to replace both the gaskets between the carb and the carb box and between the box and the engine casing.
Jun 11, 2010 | Peg Perego Vespa Scooter
I brought vespa lml 04 plate of lad that put a 180 malosi kit on got good comprstion great runner when running but night mare to start have to kick start for ages and wont start with air filter on once got...
Try turning the idle screw which protrudes from the air filter box anti clockwise once it's running. Or try taking your air filter off and drilling two holes (5mm + 7mm) in the little 'heart shaped' depression on the bottom of it.
Jun 10, 2010 | Peg Perego Vespa Scooter
Can i shim the rear wheel of my lml so i can fit 100/90/10tyres
Yes. All you need is to fit extra washers to the wheel to clear the exhaust.
Jan 26, 2010 | Peg Perego Vespa Scooter
User manual for lml vespa
Go to http://www.retrevo.com/ For your manuals
Best Reguards
Larry
Dec 30, 2009 | Peg Perego Vespa Scooter
When i kick my scooter(vespa 125cc) off its ok if i stop and it cools down it wont kick off but if i bump it off it fires up ok
I don't know much about Vespa scooters but from what you're describing, your valves need adjusting. If the valve is standing open as little as one thousandth of a inch, you won't have enough compression to start the engine at kick starter cranking speeds. It will start when you push the scooter and bump it off. This is because you get a higher piston speed allowing the engine to start before the compression has time to bleed off. Check the valve adjustment,especially the exhaust valve.
Oct 17, 2009 | Bajaj Chetak Motorcycles
Peg Perego Vespa Scooter Logo
406 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
