Question about Vacuums
Old (60's /70's??) commercial type hoover guardsman upright: connection between bag or bag cover and the main 'vaccuum' became disconnected. Can't seem to reattach.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=754094
Generic problem for all Vacuums
Posted by jaqueshardge on Jul 07, 2008
Old (60's /70's??) commercial type Hoover guardsman upright: connection between bag or bag cover and the main 'vacuum' became disconnected. Can't seem to reattach.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Most of the older Hoover Comm’l type vacuums have a shake our bag with a slide on clamp – so you would keep the clamp & then either the bag usually is wired on @ the bottom of the fill area & would need to re-attach if the outer bag is still in good shape. If not then I suggest that you replace the bag and clamp if needed. include the brand name & model # with your request to either company. Questions? Contact the Hoover website or Hoover cust service @ the info listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 08, 2008
Bag is empty but it vaccuum still says bag needs to be checked?
you need to blow out the insides some how like with an air compresser
Mar 18, 2012 | Hoover U5227-930 Elite Upright Vacuum
Where do I find the bags for this old c1403 one?
Were these generic bags or Hoove brand? Also, I believe that some bags have a rubber seal on the inside of the hole to attach. I hope this helps. Type A is the correct one.
Apr 21, 2010 | Hoover Commercial C1403 Bagged Upright...
Hoover 1800 telios vacuum cleaner - fuse good but does not switch
there is a button left beside of vaccuum cleaner tube to pull it up & bag will open.
Mar 03, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
I tried to start it and it wont start it isnt the outlit Please help
Internal switch may be too tight to toggle and became disconnected from plastic mechanical slide mechanism. Replace switch for $20.00 and you should be good to go.
Jan 15, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Removing the pulley from the shaft on a hoover c1433 to replace the fan or impeller.
Removal of the pulley requires extreme care. There is a small opening on the side of the black motor housing to allow a special tool (or a screwdriver) to fit on a slot on the armature to keep it from rotating while the pulley is unscrewed. You MUST NOT touch the magnet wire on the armature. If you nick or break it, the motor may fail.
The only other method requires the motor case to be seperated to permit you to hold the armature while unscrewing.
Oct 12, 2009 | Hoover Commercial Guardsman C1433 Upright...
Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Hoover Commercial Windtunnel C1705-900
I do not know what price you have, but it depends on the condition of the vac, compared with new exact replacement.
Jan 23, 2009 | Hoover Commercial Windtunnel C1705-900...
Hoover Breathe Easy
Check that the bag has actually been installed properly.  If the plastic door lock has been broken off you may need to order a new door / bin cover from Hoover themselves. The only other way that the bag is popping off is because something may be clogged in the main dirt channel feeder leading to the bag.
Apr 24, 2008 | Hoover U5106-900 Breathe Easy Bagged...
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
