Question about Daewoo Washing Machines
I regrettably have a Daewoo Air Power DWF-1150p washing maching which is giving me endless problems. Without fail it Knocks,Bounces, Shakes and virtually wants to jump out of its casing. The moment the drum begins turning it's as if the insides are going to explode out of the body work. i've checked the hoses for any possible blockages- all clear. The stabilising bars - all secure. The inlet and outlet hoses- all clear. There is absolutely nothing wrong with the electronics, programmes or cycles. IT"S ALL MECHANICAL. IT DOES NOT SEEM TO COUNTER BALANCE ITSELF WHEN THE DRUM STARTS SPINNING. DAEWOO you created this MONSTER so please SORT IT OUT. Deon Cape Town South Africa.
    Top Expert:
  • Daewoo Master
  • 26,713 Answers
Check the concrete balance blocks are fitted.
Posted on Mar 31, 2017
5 Suggested Answers
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
  • 4 Answers
SOURCE: Whirlpool Front loading washing Machine
Try checking the brushes in the motor.
Posted on Dec 13, 2008
SOURCE: washing machine shakes excessively during spin cycle
Change the three wear pads
Posted on May 20, 2009
SOURCE: I have a DAEWOO DWF-1150P top loader washing
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Posted on Jul 10, 2011
I have a Daewoo DWF-1150P top loader, but once the water has been added it's not washing
Check to see if the motor is running? How about the drum belt - is it on the pulley? Is it slipping?
Aug 12, 2015 | Daewoo Washing Machines
What is the exact belt size of Daewoo Fuzzy Logic washing machine 7.5 kg dwf-75ts? Where can I order this?
Hi,if you still have the old belt,take it to the shop and ask them to give you a replacement.
all the best.
Apr 28, 2015 | Daewoo Washing Machines
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
Mode W/M-DWF-200MP
Apr 29, 2010 | Daewoo Washing Machines
Dwf-6010ap
I HAVE DAEWOO WASHING MACHINE MODEL DWF-6010AP
THE PROBLEM IS THAT COLD INLET IS LEAKING WHEN RUNNING I NEEDS SOLUTION OR WHERE CAN I GET PARTS
Jun 25, 2008 | Daewoo Washing Machines
Washing Machines Logo
83 people viewed this question
Top Daewoo Washing Machines Experts
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
