Question about Garden
Wat do you use the back infared burner for is it for rottiserie?
    Novelist:
  • 171 Answers
Yes. Most of them have a 1500 degree heat so they do a fantastic job of cooking.
Just buy a rottiserie, hook it up, and enjoy!
Posted on Jan 11, 2011
Infared burners ignitor won't work
Mike, have you replaced the battery in the igniter button ye? That's the first place to start troubleshooting. Be sure you install the new battery facing the same direction as the old battery. Also, check the interior contacts of the battery holder for corrosion. If you find any, use a Q-Tip sprayed with a little WD40 to clean it.
If the above doesn't solve the problem, trace the igniter wire from the igniter button to the spark igniter at the burner for damaged wire or a loose connection.
And finally, try match lighting the infrared burners to make sure that they are getting an adequate flow of gas.
Hope this helped you t troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Aug 24, 2011 | Weber-Stephen Products Weber Summit...
Good Afternoon..On my Tuscany grill only 1 of the 3 burners work. looking from left to right, the left one does not work at all and the middle burner barely. No smell of gas on the 1st and very little in...
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 19, 2011 | Altima Technologies AGR48PF Grill
I can't thottle the heat. Even on low setting everything burns up.
If the burner is infared the refractoy coud be cracked or worn and may need to be replaced.
Oct 28, 2009 | Tec Patio II Grill
Dont know how to use infared
just shine the other infared into the your computers infared that should work it did with mine
Apr 18, 2009 | Computers & Internet
Only the infared burner does not ignite.
If you have a push button sparker the wire may be off or the sparker may be worn. You can check for spark when it is dark out. If you dont think you have spark then try to light the burner the "old school" way just hold a match or flame to the white area and then turn and hold the gas knob. If you can light it the old school way then its your spark. I would remove the sparker (unscrew the plastic nut on it remove the wire if its stll on) and test it on your hand. If the sparker works you will know because you will get a shock from the end of it. If you dont get a shock then you need to buy a new one. I hope this helps
Feb 02, 2009 | Dacor OB36 Gas Grill
Need to replace infared eye on 36AF41 Toshiba TV
Yes, the back needs to be removed and the main board slides out to gain access to the IR sensor. Usually, the sensor itself is fine, the connections can get broken. Try resoldering the 3 pins for the sensor first. That alone may resolve the problem.
Keep us posted.
Dan
Jan 30, 2009 | Toshiba 32A41 32" TV
Infared burners with flame at the tops of them
This may mean that the plaques are cracked, if they are cracked you cannot repair them, you would just have to replace them. You can contact Master Parts they may be able to help you. You can contact them toll free at 800-446-1446. Thank you
Nov 10, 2008 | Procom ML300HGA Heater
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
