Question about Refrigerators
I have 2 door fridge freezer. The base of the freezer compartment is swelling. Can you tell me whats wrong please?
  • Refrigerators Master
  • 43,501 Answers
The freezer is not defrosting properly, so the ice is building up and swelling the base....
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 02, 2011
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
My maytag french bottom freezer drawer fridge has stopped working.model MFI2568AES I found out that the door was cracked open for about a week and the problem worsened over time .... I have since cleaned...
Not exactly sure whats going on based on your description. But let me tell you what I had to deal with:
Same situation where some fool left the drawer open, it caused the railings inside the drawer to freeze. I applied heat with a blow dryer to thaw it and had to realign it.
I've also realized that the freezer unit is what supplied cooling to the rest of the refrigerator (through forced air) and noticed that it works the same way with all the fridges ive delt with (maybe around 15 or so). So it doesn't make sense, if the freezer isn't cooling then the fridge shouldn't be either being that it uses the same source and it passes through the freezer first.
That said, I wonder if the fridge compartment is cooling?
Do you hear the compressor running?
Sep 20, 2014 | Refrigerators
The fridge keeps beeping every few hours and you need to keep pressing the button in when it beeps also thetop of the fridgeis not cold as it should be
Generally either the fridge of freezer internal fan motor isn't working. The beeping is telling you there is something wrong. You can check this with a strong magenet on the door switch. Leave one door closed and put the magenet on the door switch and the light will go off. Then feel the back of the internal wall and see if you can feel air movement. Then check the other compartment the same way.
Mar 23, 2011 | Fisher and Paykel Active Smart E522B...
Icing of freezer compartment. compartment freezes and pushes doors open.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ice forming in freezer compartment base or floor of compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 28, 2010 | LG LSC26905TT Side by Side Refrigerator
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Oct 26, 2017 | Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
