Question about Rowenta DG-980 Iron
I have a self-cleaning Rowenta iron. How do I use the self-cleaning function?
  • Roland Wong
    Roland Wong May 11, 2010
    If you have a current model unit, go to the Rowenta website and see if you can view the PDF of the owners manual for details on using your new iron. Generally, the self-cleaning function is a special mode/setting to enable iron to generate a burst of steam that forces deposits in the system out the sole plate of your iron. You should face it down way from you, about 8-10 inches from your ironing board surface so any debris that gets forced out will go onto the ironing board where you can check and clean it off. Only use demineralized clear drinking water or filtered tap water in your iron.
DiYerTech
  • 70 Answers
SOURCE: Rowenta DM273 Self Cleaning Function
Attached below is the Rowenta website to obtain PDF copies of the manuals. If the hyperlink does not work, cut and paste it into your browser's address line. There are also links to download Adobe Acrobat Reader to allow you to view and print the documents if you do not have this program. Please advise if you find this helpful...
http://www.rowenta.com/rowenta/frame.aspx?page=http://www.rowenta.com/rowenta/consumer_care/use_n_care/downloadInstructions.aspx?RblCategory=Download
Posted on Jul 14, 2008
  • 3 Answers
SOURCE: Self cleaning function on Signature cordless iron, S016.
Check their web site at http://www.rowentausa.com/rowenta/frame.aspx
Posted on Aug 30, 2008
  • 109 Answers
SOURCE: need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Posted on Mar 26, 2009
  • 11 Answers
SOURCE: Rowenta DZ5080 iron -lost manual - how do you go
I prefeer to put calgon in the tank where you put water.
Posted on May 12, 2009
SOURCE: self cleaning instuctions
Hello there, my iron laser rowenta pro is  dirty and dont have my book again, some red brown water is coming out, please i need help thanks
Posted on Dec 03, 2009
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
How do you clean the DM580 Rowenta iron? It is
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Feb 06, 2010 | Rowenta Precision DM580 Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Brown water staining clothes when ironing
either the water has sat in the iron too long between uses
or its the iron in the water you use.
you will have to flush out the old water.
try distilled water
Jun 27, 2009 | Rowenta DX6700 Iron
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
Rowenta DZ5080 iron -lost manual - how do you go about the "self-clean" ?
I actually found the manual online - copied the pages needed for my wife to confirm how to perform "the self-clean". Took a while surfing but worth the time. Thanks.
May 11, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
Jul 05, 2008 | Rowenta Perfect Iron
How to clean
heres a link to help you out , also I recommend to get "CLR" cleaning product , hope it helps AJ
Jun 12, 2008 | Rowenta DX6700 Iron
Rowenta DG-980 Iron Logo
3,281 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
