Question about Fujitsu Heating & Cooling
I have "EE" in my temp Display after a power
  • 2,133 Answers
Press < and > or + and - at a time for 5 seconds.Helpful?
Posted on Dec 30, 2010
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
I am getting the message "Ink System has failed. Unable to print. Refer to printer documentation. Error:0xc18a0001." I have tried to shut it down and back on and it's still not working -...
1. Get the unit into the "Support Menu" by following the steps below according with the product,
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
C. - Press and release the "OK" button
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. If the error is still there, or reoccurs replace the unit.
VOTE ME IF YOU LIKE THIS SOLUTION
Aug 12, 2011 | HP PhotoSmart C5150 All-In-One InkJet...
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Demo mode rs255sl
This function is for a display purpose on the floor of show room or store.
1) Mode ON/OFF
1-1) For the exhibition mode, press Power Freeze and Freezer Temp. buttons simultaneously for 8 seconds until a
“ding-dong” sounds.
1-2) Press the same time buttons again for 8 seconds to cancel this mode put with a “ding-dong” sound.
2) Operation
2-1) Most of the system function except the compressor operation are working properly.
2-2) There is no defrost cycle in this mode.
Mar 21, 2010 | Samsung RS265LBBP Side by Side...
I have a HP Photosmart C6180 All-in-One printer. It's giving me a Ink System Failure...Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error Oxc18a020 Turn...
A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
Mar 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Fridge temp will not drop to set temp
if you have had a sudden power failure or power spike, you may need to reset the fridge. This can be done by holding down the power freeze button and the fridge temp button together for about 5 seconds. The fridge display will go blank. press the buttons together again, the fridge display should return and both fridge and freezer should be reset
Apr 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Heating & Cooling Logo
401 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
