Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad.
  • nigelhoyow Oct 04, 2008
    Turned the refrigerator control to 0 (off) to clean inside. After about an hour turned the control back to factory setting but refrigerator does not come on. The freezer section is working fine - did not turn that side off.
    3 hours later, the refrigerator still is not on - what is happening?
My problem also is that freezer is cold but fridge gets warm. When I turn the whole thing off for a sort time it works again.
How would I know which part needs to be replaced to repair this?
Rod
rodbutler@psci.net
Posted on Aug 12, 2008
Had this same problem. Ice formed on the back of the freezer compartment, but the refriderator area would be about 50 degrees. Checked the fan and defroster timer and everything worked fine. Watched it all defrost and ice build up again. Finally called for service. First guy said he needed to take the unit back to the shop. Second guy said there was an internal leak in the sealed case...couldn't be fixed. Finally realized I had bought an extended warranty (yippee!!) and called the authorized service dealer. Tech came out, said there was a service bulletin whereby the freon line by the evaporator coils was bent a little to extremly and was causing a restriction in the freon...thus the ice build up. He tweaked the line a little and now it has run perfect for 6 months. Would be nice if these bulletins from the factory were posted somewhere...
Posted on Oct 05, 2008
FRIDGE DOESN'T GET COLD NEW THERMOSTAT DEFROST TIMER . THE ONLY THING NOT WORKING IS DEFROST ELEMENT DOESN'T TURN ON WOULD THE STOP IT FOR COOLING
Posted on Jul 01, 2010
I have a compact wine cooler. it will get cold but the fan inside at the top makes a LOUD noise and seem to keep getting stuck...If I hit the top with my had, fan starts to run again refrig. gets cold and shuts off. when it start to run again, Fan at the top won"t start to run unless I hit it again at the top....Whats up?
Posted on Jul 09, 2009
Thank you Micbeth1981 - well I plugged everything out from the wall plug and let the whole thing defrost overnight (about 6 hours) when I turned it back on in the morning - everything started working as normal - it looked as if the fan in the top left of the refrigerator section had frozen up.....just like you said..... 2 days later and it is going great.... I don't see the ice sheet anymore in the freezer section and the refrigerator is nice and cold now. I set the refrigerator section to 1 more notch than the "factory setting". I am in the tropics so need it cold !!
Next time I will plug everything out and not leave one side working - maybe that was the cause of this whole episode. If it happens again I will take off the back panel and have a look.
But, if the fan stopped like it did - will it not damage the fan motor? I hope not. It's blowing up a storm now and I dont hear any funny noises.
Posted on Oct 07, 2008
    Genius:
  • 1,122 Answers
ONE OF FOUR THINGS IS HAPPENING,YOUR FAN IN FREEZER HAS STOPPED,YOUR DEFROST THERMOSTAT IS BAD,YOUR DEFROST HEATER IS BAD,OR THE DEFROST TIMER IS BAD,REMOVE THE FREEZER BACK PANEL AND YOU CAN CHECK ALL BUT THE DEFROST TIMER DEPENDING ON MODEL MOST ARE IN THE FRIG.,LET ME KNOW-MIKE
Posted on Jul 07, 2008
2 Suggested Answers
  • 40 Answers
SOURCE: my frigidaire refrigerator does not
you have a defrost problem either a bimetal thermostat, defrost timer or a heater. open doors and unplug unit for 2 days to let defrost it will work great for a week or so. not to costly to fix either way
Posted on Feb 23, 2009
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
My freezer is very cold but not freezing water into ice. The door was only partially closed because a towel was in the way but after fixing that it has been 6 hours and it's still not freezing. The...
That really cause the freezer not to freeze water because of that towel. Since you already remove the obstruction, just observe it and it will gonna freeze the water. Be sure that the door gasket magnet has tightly closed freezer door and no cold air is going outside. If there is, again it will takes longer to freeze water into ice.
Just observe and it will gonna go back to normal operation.
Good luck to you.
Jul 03, 2011 | Frigidaire Side By Side Refrigerator 26...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad. unthawing in freezer...
Feb 23, 2009 | Frigidaire FRS26R4A Side by Side...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Freezer not frezzing
DR....let's go down the list:
First is freeze up. This happens when too much humidity gets into the unit from the air and forms ice on the coils. Defrost the unit using warm air or leave it open and off for two days.
Problems that cause this: high humidity, 'window shopping', unit not left closed or bad gasket. If the gasket looks damaged, it will need to be replaced. Gaskets that have accumulated dirt don't seal. Use a mild cleaner to fix this. If you have doubts about an area where the seal is questionable...use a sheet of paper about 2-3 inches wide, close the door and pull it through. No resistance indicates a poor seal.
Make sure you clean out the condenser...the coils where the heat is rejected by the unit.
It is possible that you have refrigerant or defrost timer issues. To check for low refrigerant, start the unit after defrosting it. Note that the larger pipe attached to the big black thing....the compressor...will start to frost. It should then start to form ice while the unit is running...about 5 minutes. If the frost stays and the pipe is not REALLY cold, you have a problem with refrigerant. Sealed units are warranted for 5 years. Defrost timer issues are best left to a tech.
Dec 02, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
1,017 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
