Question about HP LaserJet M1522n MultiFunction Printer
Hi my printer hplaserjetm1522nf not connect with wirlesnetwork(cisco). I can't fix this problems.pc find this printer by network but don't connect.
  • HP Master
  • 7,733 Answers
Go to Wireless Printing Center .
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Dec 30, 2010
Need driver for cisco rj45 to d9
You don´t need a driver. You need a serial port on your PC/laptop and a terminal-software, such as Hyperterminal. Do not forget to set the terminal-speed to 9600 (this is standard on Cisco-routers).
hth, Karl
Feb 14, 2013 | Cisco Compatible DB9 to RJ45 Console...
It says my printer is offline, but it is plugged into the network and is on. Any idea of how to fix that?
the software of your printer id corrupted re installing the software application will resolve the problem..
Sep 30, 2011 | Brother HL 2270DW Laser Printer
I have a problem with my HP LaserJet P2015dn. When a print job is sent to the printer, it will not print unless I turn the printer off and then back on. This printer is used on a small business network.
This is a common issue with these printers and it is usually one of two issues:
1. The formatter is failing. HP used to replace them free of charge because of on going defects, but that program has expired due to age of machines.
2. Some business class routers such as CISCO, will lose track of the printer becuase HP products do not constantly broadcast their IP address. If you are using a CISCO product you can try entering a static enterly into the ARP table of the router to see if that fixes the problem.
If you are not using CISCO network gear then it is more likey option 1
Jun 10, 2011 | Office Equipment & Supplies
Problem with setting up a wireless connection using the AM10 USB Wireless Network Adaptor. The device is listed in Device Manager as working properly, but under Network Connections, the status for the...
Looks like, you are installing in vista or Windows 7..Sometimes in these OS , it needs elevated privilages..Try to enable in Network connection by clicking RIGHT CLICK on network icon & run as Administrator privilage..OR try to install with Administrator privilages...I hope this will work
OR if there is driver problem,,Try to download drivers from the below link
http://homesupport.cisco.com/en-us/wireless/valet/AM10
Please rate & vote if you like solutions
Thanks
Sandeep
Mar 13, 2011 | Linksys Valet by Cisco AM10 Valet...
2Wire Home Portal 1100 for AT&T DSL connection problem
HI! read your posting regarding the situation that your experiencing.. If before you dont have any problem regrding your connection with out the cisco network magic. I suggest that before you install the cisco network magic. you should get the full version not the trial version, there is a limitation of setting up the trial version.. Cisco network magic is a plug and play and easy to setup if you get the full version. I dont see any problem regarding your connection with the 2wire and the linksys router, becoz you mention earlier that hime network is working and you can connect to the network and the internet..
Jul 24, 2009 | 2wire Computers & Internet
The ping response time is very bad on Cisco 6506.
It should be Layer 1 Issue (Physical connection). Your cable, PC's Ethernet card or the Interface in your Cisco it self.
P.S.: If this information was helpful, please rate this solution. aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Feb 24, 2009 | Cisco Catalyst 6506 chassis Networking...
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Connecting to console
The proper way to console to a switch (at least as far as Cisco Catalyst Switches are concerned) is a rollover cable and a DB9 adapter... I then use HyperTerminal to connect..
What type of switch are you connecting to, and what kind of hardware are you using?
I always use Cisco for networking (Cisco is the king of switches and routers).. here is their step by step for connecting to one of their swtiches:
http://tinyurl.com/b4o0
DG
Dec 25, 2007 | HP ProCurve 2524 24x10/100 Mbps Networking...
Installation of cisco asa 5510 firewall
If you can't get the manament working initially I suggest the following
Setup a console connection
Type "enable" and press enter to access priveleged exec mode on the ASA
Type "config terminal" and press enter to access configuration mode
Type "configure factory-default" and press enter to load default settings.
Assign a static IP to your PC of 192.168.1.5 and try to browse to https://192.168.1.1 (PC is plugged into management interface)
You should be prompted to begin using ASDM
Jul 30, 2007 | Cisco ASA 5510 Firewall
HP LaserJet M1522n MultiFunction Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
