I also have had the "ld" problem, the repair man came today and said it was the pump. My husband changed the pump out, and still the "ld" symbol appears. I guess I'll be calling the repair man again.
Cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
I recieved a "LD code on my washer I turned it off and it would not work. Now to get it to work I have to unplug it and wait 5 minutes and I plug it back in and it works fine.
The Ld error is flashing, and the washer stops, the manual says to check the drain hose, I have looks fine
I have the same problem. My washer keeps flashing the ld and beeping. The repair man came out and says the pump needs to be replaced. I've had him order the part but after reading this I realize I need to ask him what happens if he changes the pump and the problem continues (before I pay)!! I also have a high pitched noise that drives me crazy and the repairman said its the valve. I'm having the valve and pump replaced and my boyfriend says I'm nuts. That for that price I should just buy a new, more dependable washer!! Ug!
I am having the same issue for a while now . my machine starts flashing LD when 16 minutes remain for the cycle .. i have to switch it to rinse and drain for completing the wash cycle. I purchased the machine from LOWES a year ago.
