Question about Microsoft Xbox 360 Console
If nothing of the above works... Give it a light tap.
    Sergeant:
    Champion:
  • 226 Answers
Are u red light. what worng with it xbox360.
Posted on Dec 30, 2010
Did my center dash lights short out
oops, you blew up something with bad wiring,
why not let a pro wire your car, with out hacking it.
that tape is mark of a NON PRO work.
it's doomed,
Jan 29, 2015 | 2013 Toyota Tundra
Picture problem very dark, ok only on 1/4 of screen then that goes dark, try nothing yet it wolud work if you tap side of tv but that dose nothing now tv is samsung 7 series 40" flat screen
This is a common fault as the set on ageing deteriorates in the connections. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Jul 12, 2011 | Samsung Televison & Video
Hi. I have a Ford Expedition Eddie Bauer 99' form brand new. My problem now is that the heater is not working. In Straus auto service change the heater core, the thermostate and another square piece that...
Maybe the blower motor is not working, they give no warning signs, they just quit. If you tap lightly on it, it might blow just to get you by for now.
Jan 14, 2011 | Ford Expedition Cars & Trucks
Will not turn over with good battery after it set
disconnect your belts and try and see if it starts. you may have a locked up a/c compressor or alternator. If nothing, tap on the starter with a hammer. Give it a couple of good taps and see if that helps any.
Nov 01, 2009 | 1993 Oldsmobile Cutlass Ciera
My bike starts but dies right away what's wrong
Sounds as if you don't have any gas to give it! Turn off the tank fuel tap, remove the carburetor fuel hose, and place the end in a clean can or jar. Turn on the tap again--you should get a small stream of fuel running from the hose. If it just drips, turn off the tap again, unscrew the small bowl under the tap and remove the brass filter screen just above the bowl. Soak it for a while in carburetor cleaner, rinse in fresh cleaner, then put it all back together. Turn on tap again and check for fuel flow. If still weak, turn the tap to 'reserve' position--is the flow still weak? If so, remove the fuel tap bowl and place the can/jar underneath and turn the tap on again. If still slow, open the fuel cap up on top to make sure that tank vacuum is not stopping flow. If nothing helps, you will need to remove the tank, drain the fuel out and remove the fuel tap to clean the two tubes that are sticking out of the top. You may need compressed air to get this accomplished. Good luck!
Oct 21, 2009 | 1988 Honda XR 250 R
1996 Jeep Grand Cherokee Laredo It sat
Try gently tapping the starter motor with a hammer or bar. There may be a bad contact in the sollenoid or the starter motor brushes worn to their limit. Tapping may give you a tempory fix if the problem lies in the starter motor.
Aug 12, 2009 | 1996 Jeep Grand Cherokee
My 1997 honda accord wont start.....
Hi Matt
Follow the( + ) positive lead from the battery, to the starter, check the connections, if all OK, get someone to turn the ignition key to start, and give the starter a tap, on the selenoid, with a small hammer or a metal socket extension.
Good Luck !
Let me know the outcome !
Also a FixYa rating would be nice !
John
Feb 10, 2009 | 1997 Honda Accord
HP Pavilion dv9843 notebook
Most likely you have to double tap. Depending on the laptop make, sometimes double tapping isn't intergrated.
Jun 29, 2008 | HP Pavilion dv4000 Notebook
Xbox 360
tap on right above the drive if a tap doesn't work just hit a little harder mine does it every now and then it will pop open
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
