Question about Achiever CCS5000 Shredder
Shredder won't turn on - Achiever CCS5000 Shredder
  • 1 more comment
  • Anonymous Sep 07, 2008
    Will not turn on
  • cruty Sep 08, 2008
    Shredder wont ron when plugged in and turned on. Have tried cleaning out where paper is inserted. Switch is not blocked.
  • pcine Jan 14, 2009
    my CCS5000 schredder will not turn on, does anyone know what the problem is? I have the fuse replaced already and still nothing happens.
  • 57 Answers
Has your problem been solved
Please get back to me
Thanks
Posted on Jul 23, 2008
My ccs5000 achiever will not turn on, I replaced the fuse still nothing what can I do to fix this problem?
please help
Posted on Jan 14, 2009
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
Nov 28, 2014 | Staples SPL826X (CrossCut) Shredder
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Won't shut off
You have an optic sensor that is blocked or shorted. If you take it apart you should be able to identify the problem. It is up by where the paper feeds in.
Jan 08, 2013 | Royal 1610X Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
As501 shredder. reverse works. Auto won't go.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Jun 05, 2011 | Aurora Global AS501X-MS Shredder
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
Have a new electric shredder does not have
Brand new shredder with no owners manuall I plugged it in.it won't start is there a first time procedure t o use it
Jul 10, 2010 | McCulloch Electric Chipper Shredder
No Power!
Check and make sure the paper catch bin is locked into place.
IF the shredder doesn't see that the bin is in place, the shredder will appear dead for safetly reasons.
There is a possibility that the control board was cracked but the only way to check that, is to take it apart and check.
Good luck.
Jan 06, 2008 | Tech Solution TS-4500 Shredder
Achiever CCS5000 Shredder Logo
303 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
