Question about Microsoft Windows Vista Ultimate Edition
Windows registry errors
Please help me in removing prgramming errors in shareddll, file/path references, empty registry keys, program shortcuts in windows registry of OS windows vista.
    Sergeant:
  • 233 Answers
Get the{ TuneUp Utilities } software it is very helpfull and easy
Posted on Jul 08, 2008
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    Error on system
    Dll errors occur due to various reasons incomplete installation or removal of a program, missing, corrupt, or incorrect .dll file paths, and more. Failure to fix these errors can result with severe PC problems click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box then select check now start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer also download a registry cleaner http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Hope it helps.
    Dec 30, 2012 | Microsoft Windows Vista Ultimate with SP1...
    I have CreataCard Platinum 8 version installed on my computer. Recently, I had to uninstall it and then re-install it due to some computer problems. I just tried to access the program and I keep getting...
    Hi.
    If you are unable to uninstall the software by way of 'Add or Remove Programs' or 'Programs and Features', it will be necessary for you to perform a manual uninstall by searching the hard drive for files and folders related to the program you want to uninstall. then manually removing those files and folders.
    Many programs will install files and folders in several locations on the hard drive. And, even when it is possible to uninstall software by way of 'Add or Remove Programs' or 'Programs and Features', it is always a good idea to conduct a search of the entire hard drive then manually delete any files, folders, icons and shortcuts that are found by that search because many uninstall processes do not remove all files, folders, desktop icons and Start menu shortcuts associated with the software.
    After making sure that all files, folders, icons and shortcuts have been removed from the computer, empty the Recycle Bin, restart the computer, then run a registry cleaner until no invalid registry entries are found. It is advisable to run the registry cleaner REPEATEDLY (always restart the computer before running the registry cleaner again) because fixing some invalid registry entries can cause other registry entries to become invalid.
    If you are uninstalling the program because you believe that the installation is corrupt, these steps are especially important . Making sure that all files, folders, icons and shortcuts are manually deleted and using a registry cleaner to remove all invalid registry entries is the best way to ensure that all corruptioIf you don't have a registry cleaner installed on your computer, you can download the free CCleaner by clicking on the link below
    Download Latest Version of CCleaner
    If you use CCleaner, you must remember to click on the 'Registry' button on the left side of the window before starting the scan. And, with CCleaner, running the registry cleaner repeatedly will often cause the same invalid registry entries to be displayed over and over. If that happens more than twice, the only option is to allow those invalid registry entries to remain - because indications are that those invalid registry entries are not truly
    invalid at all.
    There is also an option to try and uninstall a program using CCleaner. If you click on "Tools" option on the left hand side, click on "Uninstall" and look down that list for Creatacard and try and uninstall the software using that option.
    The 'Cleaner' option in CCleaner is a very useful tool for cleaning out unnecessary files and folders on the hard drive. So, it is also be a good idea to run the 'Cleaner' option in addition to the 'Registry' option.
    Once you are sure that all traces have been removed restart your computer and proceed to re-install the software again.
    Hope this helps.
    Regards.
    Jun 02, 2011 | Broderbund American Greetings Creatacard...
    Cannot install Pinnacle Studio 12 Video editting
    Make sure to back up the registry before modifying it. For more information about the registry, refer to your Windows documentation or contact Microsoft.
    1. Choose Start > Run.
    2. In the Open box type Regedit and click OK.
    3. Browse to the following keys:
      HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
      HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    4. Verify the drive, path, or variables are valid for each of the keys.
      For each of these keys on the right hand side there is a Data column. Each entry that refers to a variable or a path name - each value needs to refer to a valid drive, path or variable. These path names may be unique to your individual PC - to restore the defaults it may be necessary to examine a known working machine, or contact a Microsoft Windows technician for additional help.
    Jan 04, 2010 | Pinnacle Studio Ultimate 12 for PC
    Unistalling Oracle
    You will need to re install it and then uninstall it for cleaning it completely, but it will still shows information in registry as long as registry does not deletes it after few months.
    You can also manually delete it from your program file folders.
    Sep 11, 2009 | Oracle Database 10g
    Can't get itunes to work
    The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
    Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
    The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
    The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
    The two Registry locations that list the My Music path are the following two:
    Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
    Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
    Make sure you follow the correct registry entry.
    Apr 26, 2009 | Apple iTunes
    Error in registry....
    Maybe, you have registry problem.
    • Just restart the system
    • Press F8 while starting the windows
    • Select "Safe Mode" options
    • After restarting, a window will come up on screen
    • select No
    • Just select the past date from the date calender. You must select a past date from which you were not facing problem.
    • A restore process will start automatically.
    • press okey and finish
    • restart the computer.
    Dec 10, 2008 | Microsoft Windows XP Professional
    Error in registry
    The easy way is to make windows repair itself, this can be done by starting your pc from the windows cd, then when the blue screen appears with 3 options,
    ..install windows,...repaire,...quite ..F3,
    press enter for installation, then F8 to accept, then windows setup will search for installed OS and then asked you to press R to repair it, from this point you can press R and wait while installer delete windows system files the reinstall them without loosing your installed programs.
    Dec 10, 2008 | Computers & Internet
    Error that wont go away
    Please be careful when running any sort of tools on the registry. Since almost everything in windows has a registry entry you MUST be very carefull when doing anything to the registry. IMPORTENT : Back-up the registry BEFORE doing anything to it. The problems you are having right now COULD be because of changes made to the registry. It is hard to know because you didn't post EXACTLY what the error messages were. I can only guess what happened: 1) Possibly references to .net driver paths where re-written or deleted, A re-install of windows .net should fix this problem. 2) The path to your outlook inbox files could have been rewritten and/or possibly deleted. If you cannot find the path to these files (if they are still there) and enter that path in to the registry, then you have probably lost your local copy of your saved email. In that case there is no fix. My recommendations: 1) Always back-up, back-up, and back-up some more (you never know when something will go wrong) 2) Always take note of the exact error messages the computer gives you. It is THE only solution to any problem. Also to save you panicking, most of the registry entries regcure reports on (as with ALL registry repair tools) are NOT a problem. MOST of these entries are MRU entries (recent files applications remember), missing shortcuts, directory's and the like, nothing of which will harm your computer. You really only need to run a registry cleaner once every few months.
    Aug 16, 2007 | Microsoft Network Programming for .Net...
    Microsoft Windows Vista Ultimate Edition Logo
    43 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
