Question about Texas Instruments TI-84 Plus Calculator
I have a ti 84 plus and every time i try to add an application the error 80070016 (device does not recognize this command) comes up how do i add applications to my calculator
  • charles williams
    charles williams Dec 30, 2010
    What APP's are you trying to download?
3 Suggested Answers
SOURCE: how to restore applications on TI-84 Plus Calculator
Go onto www.education.ti.com, find the downloads column, and click on apps and operating systems. Then you can click on the different lists and find out which apps you accidentally deleted. You do this by (after clicking on it) looking under the "Pre-Loaded On" column. If you find the name of your calculator there, this is one application that was deleted. Hope this helps!
Posted on Aug 05, 2008
THIS WILL HELP YOU 4 SHO
the best way to get all your applications back is to link your friend's ti-84 plus and make a file backup, ( do this by first installing Ti graphing Product CD wich is included with the calculator) after this just connect your calculator and store the files back onto your calculator! ZOMG??? IS it that easy???
yes it is, just apply some clear thinking and ull be just as smart as i am
Posted on Sep 09, 2008
How do I fix my TI-84 Plus Silver Edition if none of the buttons will work?
Will the calculator turn on at all? If not, check the batteries first. There is a little coin battery that stores memory for the device behind where the regular batteries sit. This does not often fail, but could cause the thing to not power up. Note: removing the coin battery will clear any information stored on your calculator.
If the device is stuck in an infinite loop, or is unresponsive with the busy icon, try pressing and holding the "2nd", left, right and "on" buttons in that order and holding them all at the same time. This is the command to cancel whatever process the device is working and clear the internal memory (At least on the TI-89. I'm not 100% sure the command works on an 84).
Jun 02, 2011 | Texas Instruments TI-84 Plus Calculator
What is ERR:SYNTAX on ti-84 plus calculator
If you want to correct the error you will have to disclose what you were trying to calculate.
Anyway, each command has to be written in a specific way ( a specific sequence of symbols) to be understood by the calculator.
Foe example, if the command is sin(X) you cannot write it as sin() X or X sin. You must respect the way a command is to be entered, otherwise you get rubbish or a SYNTAX ERROR message.
Usually the calculator will ask you GO TO or QUIT. If you choose GO TO the cursor will jump to the place where the error occurred and you may be able to correct the syntax.
Apr 14, 2011 | Texas Instruments TI-84 Plus Calculator
Hello, when i try to put some teks on my TI 84+ he gives an error
Anything you enter is interpreted either as a number or a command. if the calculator does nor recognize what you write as a number or a command it gives you an error message.
If you want to use your calculator as a text editor ( a very poor one at that) you should download and install the NoteFolio application. It may already be on your calculator.
To download applications go to this web page
Jan 18, 2010 | Texas Instruments TI-84 Plus Calculator
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
The memory button on my TI-84 Plus will not function
If you connect it to the computer using ti connect device explorer you can try to do everything from there. Manage your memory. If you saying the plus sign is broke too, because it is the memory key too. I wonder if you "+">a would work. Just 2nd recall "a" when you need the plus sign. You can store it in any variable you want. Setting up systems to operate your calculator's memory management can be done on command or Entry Line. Much easier with Ti connect. You don't really need the plus sign or memory key to run very good memory management programs. Just remember to download from this site my ti 84 plus silver manual on how unarchive and run programs. I really don't recommend taking the calculator apart, they usually end up broke at that point.
Sep 18, 2009 | Texas Instruments TI-84 Plus Calculator
Cant install any applications
Run the TI connect software on you computer. Turn the calculator on and connect it to a USB port on the computer. Before you drag and drop applications on the TI connect software window, Click on one of the icons (TI Device Explorer, TI Device Info, TI Screen Capture). Two new smaller windows pop up, the one on top has the title Select TI device. If in that window it recognizes your Calculator Model, you click on select and OK, and you are ready to communicate with it.
If on the other hand, it fails to find your calculator on any of the 3 or 4 communication ports (COM3, COM4, USB1, etc.) then you click on the communication setting and in the drop down lists
Sep 03, 2009 | Texas Instruments TI-84 Plus Calculator
TI-84 dowlnoad error?
Make certain you have registered your calculator on their site. I think you need to enter you internal number. The internal number can be found by pressing the 2nd key, then the plus key and choosing about in this screen.
Jun 09, 2009 | Texas Instruments TI-84 Plus Silver...
TI 84 Change brightness command
Couldnt you just do 2nd up or down multiple times
Oct 24, 2008 | Texas Instruments TI-84 Plus Calculator
Misinterpreting Program Types
many times it all as to do with how much memory you actually have. the more games the less memory, and if you use too much memeory on the actuall files it doesnt have enough to run games, to free up space either delete some files or archive them (archiving renders them unuseable untill u rearchive them) but archiving has alot more space
also some games are not compatible with mirage os or ti 84
hope this helped
May 17, 2008 | Texas Instruments TI-84 Plus Calculator
TI 84 cant turn on
Sounds like your pc had a static charge that it discharged to your TI and that it fried something inside the TI. No warranty, No fix. You gotta buy a new one.
Apr 10, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
1,712 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
