Error code COO70 on Minolta EP1080 - Office Equipment & Supplies
3 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: minolta di 251
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Posted on Jan 11, 2008
  • 15 Answers
SOURCE: Error Code C04
Let the copier on then press S1 (reset switch ) on Board-A.
Posted on Apr 09, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
I have a minolta Photocopier CSPro EP1080 that keeps displaying an error message; C04 with a Spanner sign as well, what will I do?
Exposure lamp is burned out or the board the operates it is or both. The exposure lamp is the very bright light hat comes on when you make a copy under the the big sheet of glass. Raise the document feeder up and press start button does the bright lite come on and scanner move?
Try to reset. power off the machine, remove the top rear cover. Find the main circuit board now turn on the machine wait for code to show up and press the small black button on board lower right. if the code comes back try below parts.
Try this site for the lamp as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 10, 2015 | Minolta Office Equipment & Supplies
Minolta ep1080 is printing lines all the way across the page
Check the drum the fusing unit (The hot part) and charge corona housing above the drum when the drum unit is pulled out.
Jan 17, 2014 | Minolta EP1083 CS/PRO Copier
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Minolta ep 3050 copier error code coo70, toner bottle does not turn. have replaced toner motor.
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Nov 01, 2010 | Minolta EP1030/1030F CS/PRO Copier
Minolta EP1080 Error Code C004C - Fan Motor Problem.
Look for the ozone filter the fan next to it is bad replace it.
Oct 05, 2010 | Minolta Di3010f Printer
C04 in Ep1080
The exposure lamp is it coming on? Thats the real bright lamp under the glass where you put the orginal documents, To reset open close the front door., Code C-0410 is the lamp is on to long. Check the scanner itself that it moves any loose connections or binding?, Mite have a problem with the scanner circuit board? Second reset is behind machine, remove back cover, looking at the circuit board from the rear your left side see a small black button on the board press it. copier must be on
Aug 08, 2009 | Minolta Office Equipment & Supplies
Error Code C04
Apr 04, 2009 | Office Equipment & Supplies
Minolta di 251
Jan 11, 2008 | Canon CLC 5100 Copier
64 people viewed this question
k24674
