Question about Craig CMA3015C MP3 Player
Tengo un MP4 de 4GB modelo CMP616F manofacturado en JUNIO-2009. el problema que presenta es que cundo lo pongo a cargar 5 o 6 horas la carga nomas me dura como unas 8 canciones y se descarga esto lo hase desde que lo compre. que es lo que tengo que hacer . me gusta el aparato porque no le pide nada a otros a paratos mas sufisticados agradesco la atencion que le den a la presente atentamente juan z.
SOURCE: craig 4gb mp3 model cmp616f does nothing but blink hour glass
left craig mp3/video player model cmp616f on while disconnected from computer over night. connected to computer next day seen hour glaas 2 or 3 seconds then craig blue screen . it connected to computer and stated charging again seems to have reset its noon now dec 28 2009 ill post again results when fully charged and try to use.
Posted on Dec 28, 2009
  • 17 Answers
SOURCE: MP4 player
Press the mode button on mp4 player to find the music directory and select what you want to change to.
Posted on Jan 30, 2010
SOURCE: my mp4 player (craig model#CMP616F)will only flash
Mine did the same thing. I talked with a guy at the company and he told me it was frozen. What you need to do is let it run till the entire battery is dead. Than recharge it completely. For 4 hours at least. That should reset it. Now my player works fine.
Good luck.
Posted on Feb 24, 2010
SOURCE: mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Posted on Mar 14, 2010
SOURCE: My mp4 player craig mode
my mp4 is not show in computer
Posted on Apr 14, 2011
Mi laptop intenta encender pero no lo logra, enciende todos los leds por unos 2 segundos y luego se apaga
Es possible que tiene un problema de conector de DC:
Los s?ntomas de un gato roto del poder
1. Si menea el cable de alimentaci?n o el conector de Adaptador de C.A. en la espalda del laptop, el poder DIRIGIO y carga de bater?a DIRIGIO comienzo a parpadear.
2. La bater?a no cargar? en el laptop.
3. El laptop corre bien de una bater?a cargado.
4. Con el Adaptador de C.A. conect? el laptop parece estar muerto. Ning?n poder DIRIGIO ni carga de bater?a DIRIGIO actividad.
5. El laptop enchufa al azar lejos sin cualquier advertencia.
Si su laptop es sin garant?a, entonces puede fijar el problema por gato acerca de-soldando de DC-EN en la tabla de sistema. Si es todav?a bajo garant?a, ser?a fijado en ninguna carga a usted.
Jul 11, 2011 | HP Pavilion dv6748us Notebook
Tengo una vfr 800 2003 de primer instancia me descargaba la bateria o pila le cambie la pila x una nueva y aun sige el problema me le cambiaron la corona y sige igual x favor alguien ayudeme ya no la muevo...
Hola ranajoel_23, yo tengo una del mismo a?o y he tenido problemas con el sistema el?ctrico tambi?n. Este modelo suele dar problemas con el regulador, que si no se detecta a tiempo puede causar aver?a m?s grave en el alternador, por lo que te recomiendo que lo revises. en este foro hay una informaci?n excelente: http://www.clubvfrspain.es/index.php?topic=31881.0
Tambi?n ha tenido problemas por una mala instalaci?n de pu?os calentables, que provocaban una p?rdida de carga a la bater?a, una ver modificada la instalaci?n, no he vuelto a tener problemas.
Espero que te sirva de ayuda.
un saludo
Mar 08, 2011 | 2002 Honda VFR 800 ABS
Necesito saber cuanto es el tiempo de duracion de la bateria,en estado continuo de operacion
Hola y bienvenido a FixYa
Bueno por lo general cuando las laptops son nuevas la bateria tienden a durar hasta 4-5 horas dependiendo si estas viendo una pelicula o que recursos de la laptop estes usando, y para las netbooks cuando son nuevas tienden a durar en tiempo continuo un poco mas de 6 horas , entre 6 y 7, ojo repito estos tiempos es cuando los equipos son nuevos, recuerda que la bateria por su composicion siempre tienen un tiempo de vida y a medida que la vayas utilizando mas cargando y descargando ella se va consumiendo su tiempo de vida.
Un tip para alargar la vida de las baterias es cuando dejes cargando tu laptop y veas que ya encendio la laptop de que ya esta full carga, desconectala del cargador.
Otra cosa es si me proporcionas la marca y el modelo exacto de tu laptop y me dices cuanto tiempo tiene de uso o si es nueva te puedo decir con mucha mas precision el tiempo de duracion de la bateria de tu laptop.
Espero que esta informacion te sea util
Sinceramente,
aDynamite.
Feb 28, 2011 | Computers & Internet
Tengo un problema con un cadillac deville pasa el aseite al anticonjelante se calienta y pierde mucha fuerza asta no kerer correr mas el mecanico dice poder correjir el problema cambiando los empakes pero...
el problema de aceite mescandose con el anty congelante es por lo regular empaques de cabeza pero en algunos casos puede ser solo empaques de manifool de admission o en terminos usuales diriamos empaques de la arana asegurese que el mecanico le de un precio en caso de que solo sean los empaques de arana por logica seria mucho mas varato que los de cavezas. el caso de la cantada a que se devio le faltava agua? o estava tirando talves bueno a menos que la transmission no trabajava bien antes de la primer calentada estaria en mal estado pero si trabajo bien antes no tendra ningun problema. espero este comentario le ayude para ahorrar algo de dinero y trabajo buena suerte, informeme de lo que acontesca y grasias.
Feb 23, 2011 | 1998 Cadillac Catera
No funciona solo aparece ecipse y es todo
A mí me pasa lo mismo y lamentablemente nadie aporta una solución, el mío (Eclipse 180 8GB)se ha quedado trabado en la pantalla azul de inicio con el logo "Eclipse" y no sé que hacer. Un tipo en las respuestas en idioma inglés dice que llamó al número de atención al cliente y le dijeron que dejara que la batería descargara por completo y luego presionara por unos 30 segundos el botón "Play" (me imagino que es el botón del centro, supuestamente es la manera de resetear el player) antes de conectar el USB al PC. No sé si funciona. Mi problema empezó por una canción que no tocaba bien y reinicié el aparato, y puse de nuevo la misma canción y luego se puso el logo azul en la pantalla y éste no se quitaba a menos de mover el switch a OFF, lo pase nuevamente a ON para que descargara por completo, pero ya no lo reconoce la PC y pide drivers, se queda congelado en el logo, ni carga, ni nada.
He visto que muchas personas tienen el mismo problema y todavía no aparece ninguna solución, tú post es el primero que leo en español. Dicen que será un problema de firmware, pero no venía con un CD de drivers o una herramienta para estos casos, la empresa Mach Speed parece que todavía no tiene una página de soporte implementada para este modelo "Eclipse", también no sé como destaparlo, pues la tapa es una sola pieza. Si sabes como solucionar tu problema, házmelo saber por este medio. Talvez es de esperar, porque el firmware que tiene mi player era de septiembre del año pasado y lo compré en noviembre, el precio es bajo, pero no es posible que nos tomen el pelo de esta manera.
Feb 10, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
User manual for sciphone i9
Que tal tengo un sciPhone i9 me vino con 2 baterias ,hace 20 dias que lo compre y en un momento se me agoto la bateria ,cuando lo puse a cargar , la pantalla se me ponia en blanco en forma intermitente ( se prendia y se apagaba) lo tube varias horas enchufado y no cargo, probe colocarle la otra bateria que me trajo de fabrica y empeso a cargar bien, PUEDE SER QUE LA 1° BATERIAS YA TENGA PROBLEMAS O ES QUE LAS BATERIAS QUE TRAEN SON DE MUY MALA CALIDAD, si es haci ,que tipo de bateria puedo comprar de mejor calidad,muchas gracias por su respuesta,Saludos
Aug 16, 2010 | Cell Phones
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
Craig CMA3015C  MP3 Player Logo
100 people viewed this question
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
