Question about Toshiba e-STUDIO166 Printer
My toshiba e207 that is connected to the network in order to print i have to disconnect and reconnect the network cable every time i want to print. how to fix this?
  • 1,719 Answers
I think I only have a suggestion that may solve the issue. Try assigning Static IP to the Printer. Also, updating the drivers may help.
CreativeTECH
Posted on Dec 30, 2010
  • antonislap Dec 30, 2010
    thank you for your answer but how can i assign static IP?
  • Creative Tech
    Creative Tech Dec 30, 2010
    In order to set IP address, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
    Also, Drivers for Toshiba e-Studio 207 can be downloaded from this link.http://www.copiers.toshiba.com/support/d...
Error 49.38.07 printer unable to initialize
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.
Generally this fault occurs when a corrupt file is in the print queue
to clear fault follow these steps precisley
1. disconnect the net cable / usb cable or any other data cable that the machine is connected to
2. cycle the power with no data connections.
3. your machine should now come to ready.
4. take a copy from the platen glass ( straight forward photocopy)
if this prints out then the fault is down to corrupt data.
if at this point the error 49.xx.xx is still present then order a new formatter.
5. before reconnecting the networks -make sure ALL PRINT QUEUEs are cleared before connection otherwise you'll be back at square one
( print queues are on the computers sending print jobs)
before printing your documents its wise to send a test page through to make sure the printer is still able to understand print commands.
hope this helps...if you still need assistance please call Belmonte office equipment on 01614805556
Jan 21, 2014 | HP LaserJet Enterprise 500 MFP M525dn
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
Prior to past few days printer worked fine. Now it prints a few postcards then gives a print buffer message on printer screen and from there on it prints gobbledy gook. Now it won't even print a test...
Sounds like you cover all the bases. I just wonder if you reset the unit via the service mode?
resetting the printer should have cleared the memory.
Hold down select and return while powering on machine, hold until self test comes up on display then press go, this will get you into service mode.
Run the memory diagnostics.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Lexmark T642 Laser Printer
I have toshiba e-207.i can't connect scanner to the computer pls help me to connect scanner.
assumed that u connected the e207 to a pc via usb cable.
U need to have the Viewer 2 cd.
Install the printer
Oct 09, 2010 | Toshiba E-Studio167 Copier
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
The tipe of print head is incorrect Install the correct print head? Head is in for a long time. What shall I do?
Printer is having a brain fart. Simply disconnect all cables and power cords from equipment. Leave disconnected for 1 minute while you check connections of power cord to wall and print cable to computer. If hey are secure then wait 1 minute and reconnect your print cable to the printer, and reconnect your power cord to the printer. Now turn on printer and message should have cleared
Mar 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Cannot delete print job
Follow these steps in the order presented to resolve the issue. After you have resolved the issue, you do not need to complete any remaining steps. Step one: Check the USB cable
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Wait 10 seconds.
  3. Reconnect the USB cable to the product, and then reconnect it to the computer.
After you connect the product directly to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step. /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Nov 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Toshiba e-STUDIO166 Printer Logo
226 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
