Question about Nikon Coolpix S210 Digital Camera
.My camera shows error in
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 10, 2011
Lens error in nikon coolpix camera
Have a Canon Power Shot sx20is. When I switch on the lens moves slightly then viewer says "lens error restart camera". Please help.
Sep 13, 2012 | Nikon COOLPIX S230 Digital Camera
L18 lens error
From Nikon site...
Why does my camera show "lens error" on the screen?
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
Additionally, this link could helpfull: fixing-lens-error-on-digital-camera.html
Hope helps (remember to rate and commet this answer).
May 12, 2011 | Nikon COOLPIX L18 Digital Camera
I have canon S5 IS camera. When I power it on, it shows lens error and switches off. kindly suggest solution
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Canon PowerShot S5 IS Digital Camera
No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
May 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Lens error Casio EX-Z60
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 07, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Lens Error
well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Lens error
Jul 11, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
20 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
