Hi there, Brought the Targus AMP17AP wireless presenter with cursor control, laptop with windows XP prompting for driver to be installed but fail to allocate even with internet connected. Please help, thanks in advance. Best regards....James Ng
sandrew
  • 2961 Answers
SOURCE: D-Link DI-524 AirPlus G - Laptop Cannot Connect to the Internet
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
In the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Posted on Oct 22, 2007
SOURCE: Failed to detect an internet connection
if you are having problems with your Linksys routers, reset the router and configure it again. In configuring the router, I suggest that you use the online tool that will automatically configure your router. It is similar with the setup cd but the online tool works better. The reason why the setup cd fails is that it has its own bugs. So just use the online tool. You can get the online tool on this website--www.linksys.com/easy.
Posted on Dec 21, 2007
ronenfe
  • 91 Answers
SOURCE: how to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Posted on Mar 03, 2008
SOURCE: HP Compaq Presario C773TU with conexant HD Audio Driver for XP?
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
And then install Audio driver:
http://www.2shared.com/file/2944663/2a44c4df/sound.html
NOTE: The URL above will take you to a non HP Web site. HP does not control and is not responsible for information outside of the HP Web site.
Download Sound.zip file from 'Save file to your PC: click here' at right bottom of the website.
Extract the downloaded zip file to a folder on hard drive.
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse, Choose the location where you have saved the extracted folder.
8. Open the folder and choose the .inf file listed.
9. Ignore any errors you receive and proceed with the installation.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Posted on Jun 26, 2008
  • 16 Answers
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Posted on Aug 10, 2008
Amp11us for windows 7
i solved it eith autohotkey.... i reconfigurate all key and it's work 99%
Jan 24, 2013 | Targus AMP11US Bluetooth Presenter for Mac...
Windows 7 driver for Targus ACB10US1
your driver can be downloaded by using this pro tool: Driver Update Software for XP Vista 7 8. Have a nice day
Mike
Feb 02, 2012 | Targus USB Bluetooth Adapter (ACB10US1)...
My computer cant install the sofwear drive of (targus acb20eu) blutooth
if the driver will support the device try going to the control panel in the start menu and select add/remove programs. if you dont see it in the add/remove programs then your driver may need to be updated you can do this from the company of the computers website. just look for downloads and support.
Jan 29, 2011 | Targus 328 Feet USB-Bluetooth Adapter...
Hi, I have targus usb to 232 serialcable , model
To use a pao88 on Win7 64bit you will need to have Win7 Ultimate, Professional or Enterprise edition AND your computers processor must support hardware virtualisation.
Dowload and install the latest version of XP Mode.
Install the cable in XP mode.
Turn on USB compatibility in XP mode.
Cable will now be accessable in Win7 64bit
I connected and ran a successfull diagnostic test on an old serial modem without issue.
Oct 27, 2010 | Targus (PA084U) Network Adapter
Can the targus bluetooth presenter for mac be used on a windows system?
Sorry it can't be used on win because there are no drivers for it.
Jun 13, 2010 | Targus Bluetooth Presenter for Mac
No sound on my Lenovo 075122u.
Install these below. This will get you going http://www-307.ibm.com/pc/support/site.wss/MIGR-63244.html Networking: Wireless C100 Broadcom Wireless LAN Mini PCI Windows XP 23 Mar 2006 v4.10.47.2 Intel PRO 2915abg Mini PCI adapter Windows XP 23 Mar 2006 v9.0.3.9
Communications: Modem C100 Modem adapter Windows XP 24 Mar 2006 v7.34.0.0
Audio C100 Windows XP 23 Mar 2006 v5.10.0.5970
Power Management Windows XP 02 Jun 2006 v0.0.0.12
Intel Chipset Windows XP 23 Mar 2006 v6.1.0.1008
Video C100 Intel 900 (915GM/GMS, 910GML)
Windows XP 30 Mar 2006 v6.14.10.4384
Feb 17, 2010 | Lenovo 3000 C100 Notebook
Targus mouse not working
I checked the Targus website (http://www.targus.com/us/default.asp) for any other useful information. Use the "support" option at the website for a good troubleshooting guide for your particular mouse. Is this a new mouse? The mouse you have uses the native windows drivers and should be auto-recognized by XP. Have you kept your XP updates current? My concern is why XP could not install the software drivers needed(You would have gotten some type of an error message). Check the "details" link shown with the error message.That should point you in the right direction---rick
Sep 10, 2009 | Targus Mini Kaleidoscope (AMU0503US) Mouse
Targus Multimedia Wireless Presenter
Reload the drivers for this keyboard. Make sure that the drivers are for the OS (operating system) that you have.
Mar 27, 2008 | Computers & Internet
Lost instructions
This solution works for both TARGUS MODEL: AMP01EU and AMP01US (AMP01U AMPolu AMPolEU)
1. Connect the TARGUS reciever to the USB port on your PC.
2. Let it install 'the human interface thing...'
3. Reboot the PC (Windows 2000 and Windows XP)
4. Put fresh batteries in the handheld trackball thing (=the remote)
5. Switch the power switch on the handheld remote from OFF to ON
6. Verify that the green LED is now alive
7. On the reciever press the little button besides the enlightened RED LED to turn it off.
8. On the remote - PUSH the little hidden button on the bottom between the LASER pushbutton and the battery cover multiple times until the RED led on the reciver turns on again. (= We have now connection!)
9. SHAKE mechanichally the remote, so you hear some clicking noise from the remote.
10. Verify that the mouse cursor on the PC screen now can be controlled from the remote.
Please post here if it works or not for you.
A shorter version:
Turn the REMOTE ON
SHAKE IT FORCEFULLY
DONE.
Jul 31, 2007 | Targus AMP01US Remote Control
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
