Cannot open my SanDisk memory card when inserted into the slot on the front of my computer. Card is for a kodak camera. The software for the camera will not open the card.
  • 40 Answers
SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
Posted on Jul 05, 2007
informatica
  • 1114 Answers
SOURCE: unlock card
Take the card out from the camera & you should see a small slider on the side. Set the slider "up" as per the attached picture. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 26, 2007
  • 31 Answers
SOURCE: Cannot detect SD flash memory
check in "my computer" and see if it registers as a removable drive there. If not, then check in the device manager while the card is inserted and look for any yellow icons. There is a chance that the card reader need a driver installed or updated.
Hope this helps.
Posted on Mar 30, 2008
egadgetguy
  • 258 Answers
SOURCE: Have a dell Inspiron 1525
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Posted on Aug 18, 2008
SOURCE: HELP w/ Sandisk 4GB MicroSDHC Memory Card with SD Adapter
Not all computers can read the new HC format. I've heard of possible driver updates to fix the issue but haven't been able to locate one for my HP Pavilion yet. A temporary fix is to buy a USB HC reader. Most of them come with drivers to help a non HC compatible computer read an HC card.
Good Luck!
Posted on Sep 16, 2008
My kodak 1073is camera keeps telling me to format my new sandisk sdhc memory card when I do it tells me to insert a new card
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
Jun 23, 2012 | Kodak EasyShare M1073 IS Digital Camera
I just bought a new sandisk 4GB card for my p880 kodak. Wnen inserted the new card camera screen says card is unusable, insert new card. I have followed instructions for formatting on my PC, but still get...
The P880 works with MMC and SD cards. Your new 4GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The camera is limited to working with cards 2GB and smaller.
Sep 01, 2011 | Kodak EasyShare Z710 Digital Camera
Sandisk Memory card will not format?
hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 15, 2010 | Kodak EasyShare Z730 Digital Camera
    After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue;...
    First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
    If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
    May 14, 2010 | Kodak EasyShare Z650 Digital Camera
    How do I enter my sandisk into my kodak easyshare camera?
    Hello
    1. Open the camera memory card door on the side of the camera.
    2. Insert the camera memory card into the slot with the connecting end of the card facing the camera, and the lip on the card facing toward the front of the camera. CAUTION: The camera memory card can only be inserted one way into the camera. Forcing the card in the wrong way may damage your camera.
    3. Push the camera memory card all of the way into the card slot and then close the door. Make sure that no dirt is present when you close the door.
    Hope this can help you.
    Kind regards
    Andrea
    Nov 17, 2009 | SanDisk 2GB microSD Memory Card
    I'm trying to download photos from my memory stick to my laptop. I have misplaced the manuel. My camera is a Kodak EasyShare M109831S. Can you walk me through the process?
    Log on this website, it"s an online Kodak manual http://www.kodak.com/global/en/service/publications/urg00915toc.jhtml?pq-path=13231
    1. If the laptop is equipped with a PCMCIA card slot, insert the card adapter into the card slot on the side of the laptop. Then simply access the pictures from the associated drive letter in My Computer.
    2. If the laptop is not equipped with a PCMCIA card slot, other accessories are available. You can use a USB card reader. The required card inserts into the card reader, and you can access the pictures from the associated drive letter in My Computer c46b3b2.jpg
    Nov 16, 2009 | Kodak EasyShare M1093 IS Digital Camera
    Kodak EasyShare C653 Camera, cannot connect to my macbook
    Hello my friend,
    The easy way to upload pictures to your computer is to take the memory card from your camera and insert it to the memory card slot of your computer. i'm not sure if MAC has this slot on their computers but you can look for a PC or Laptop to do that.
    if you don't have a memory card slot in your computer, you can by an all-in-one memory cards reader which is very cheap.
    Best Regards,
    Oct 30, 2009 | Kodak EasyShare C653 Digital Camera
    When I inset my memory card into my camera it reads memory card requires formatting. What does this mean? New memory card causes prompt to format card but camera does not complete formatting successfully....
  • Feb 19, 2009 | Kodak EasyShare Z612 Digital Camera
    Memory Card required formatting
    Hello
  • Dec 26, 2008 | Kodak EasyShare Z612 Digital Camera
    I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
    hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
    Jul 19, 2008 | Kodak EasyShare C315 Digital Camera
    Computers & Internet Logo
    174 people viewed this question
    David Payne
    David Payne
